586,075 active members*
4,127 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach Slant Lathe > Anyone tried to modify .ini file for higher than 60 IPM
Results 1 to 13 of 13
    May 2008
    667
    I just would like to try a bit more than 60 IPM, maybe 65 or 70 IPM
    Can't find how to change that in the .ini file
    Look like an easy thing to do on the mill but with the lathe can't find where to insert these mods.
    Any help would be greatly appreciated, Jeff
    Re: Anyone tried to modify .ini file for higher than 60 IPM
    C&P from another post.
    I got a 2.4.2 announcement email earlier this morning.
    From the email:
    NEW KEY FUNCTIONALITY:
    • Slant PRO rapids are increased from 60 IPM to 100 IPM
    Not sure if you want that much of a change, but comparing the two might give you an idea on what to change to get your desired results.
    May 2015
    111
    If you are running v2.4.2 or later you can issue the command ADMIN RAPIDS SHOW and it will display the current settings, ADMIN RAPIDS SET xxx to set the new speed. I am pretty sure you can select from 60 to 120. No need to modify any .ini files.
    I have been running 120 in/min since it came out in beta and have not had any issues.
    May 2008
    667
    I will update Pathpilot and try this.
    Thanks, everybody
    Let me know how it works out for you. I still haven't updated.
    May 2008
    667
    Quote Originally Posted by number40Fan View Post
    Work great so far,
    I tried many way to enter what as been said "ADMIN RAPIDS SHOW" but got an error each time. Spaces, no space, underscore between each words
    But the 100 IPM is cool
    Finally updated mine today. She's a little screamer now! I'm going to need to hone in my reaction times to let off the shift key when moving the tool around to set zeros.
    Now, if we could just speed up the turret.
    I'm half tempted to edit all of the g-codes to remove the coolant and spindle off commands. The tool is now sitting there waiting for both before anything happens.
    I couldn't sleep without trying it.
    I have a program that runs like clock work. From hitting cycle start to the first tool coming back around and setting Z0 position after part is complete, has always been 5:04.
    With just the update, it dropped to 4:56.
    Edited all coolant and spindle off commands to stay on and time dropped to 4:47.
    Eh...1/4 of a minute per piece. 1 "free" part per 20 made. Better than nothing!
    May 2008
    667
    Socialist
    May 2008
    667
    I've contacted Tormach about how to go faster than 100 IPM and they won't help.
    Oooo....just noticed the backlash settings. I might have to play with that a bit.
    Nov 2007
    2151
    I posted this in another thread after looking at the lathe code posted by sprutcam
    Quick question for mike or other readers.
    The post looks like it uses g96 command in a way that would make machine start with a slow surface speed because the tool is changed at max x travel. Then as tool rapids into lead in position the spindle would want to spin up to match the rapid move!
    Is this how pp conversational works?
    Or Is this how other machines and posts work?
    if so would this not put un needed stress on spindle motor trying to change and keep up?
    Looks like machine should stay in rpm mode g97 until rapid move is over and it starts normal tool lead in. then switch to g96 and continue.
    Is this correct or am I missing something?
    After more research
    CNC Programming handbook details this to be the correct code format using the g97 then switch to g96 and continue.
    this would speed things up a bit imho!
    Nov 2007
    2151
    Quote Originally Posted by mountaindew View Post
    After more research
    This does not effect these machines much from what I can tell at this point. Most the long fast moves are along z axis. Im guessing this is detailed in cnc programming handbook because some machines with big hp power and power demands would stress if this is not addressed.
  1. Modify the Mastercam post file
    By hdthuan in forum Vectric
    Last Post: 03-27-2019, 09:05 AM
  2. Is there a way to modify an .stl file in V25?
    By mmc005 in forum BobCad-Cam
    Last Post: 09-11-2015, 01:04 AM
  3. How to use T25 and Higher
    By ggundrum in forum Fanuc
    Last Post: 05-07-2012, 03:01 PM
  4. Higher Spindle RPM?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 08-07-2007, 03:59 PM
  5. How to modify HPLG file to compensate for the speed variation of my laser engraver ?
    By g1zmo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2007, 04:16 AM
