586,103 active members*
3,389 visitors online*
    Apr 2020
    19
    TB6600_T4 Problems
    Bought a SainSmart CNC Router 4 Axis Kit, TB6600 4 Axis Stepper Motor Driver, Mach3 5 Axis Breakout Board, 4pcs Nema23 270oz-in Motor from Amazon in late December. It has a TB6600-T4. Just finished building my CNC. All good except I am not getting any voltage out to motors. Put test leads directly on screw connections to Motor’s - No Voltage !
    Was running it at exactly 40 volts, then dropped to 30 just as a test. Either way I am getting 2.7 volts from the test ground to each of the four test points. Even checked the 4 round capacitors for each motor connection; showing 38.8 volts. Green indicator lights are coming on for each axis during test. Even A as it is slaved to Y.
    Using it with Mach3. Screen indicates movement In synch with the green indicator lights on the TB6600-T4.
    Have reached an extreme level of frustration.
    Suggestions ??? Help Please.
    Note: Same msg submitted to Sain Smart but with order info.
    Oct 2013
    24
    Re: TB6600_T4 Problems
    When the system is powered up and you are not attempting a move, can you turn the motors' shafts easily? If not, the controller is properly holding the motors.
    Apr 2020
    19
    Thank you for the reply. Here are the status of the drives/pullies:
    Everything off: Pullies Turn Easily
    Control Boards On; not computer: Pullies Locked
    Computer On; Mach3 not running: Pullies Locked
    M3 Running, But No Gcode: Pullies Turn Easily
    M3 Running, Sample Gcode Running: Pullies Turn Easily
    End M3 Session: Pullies Turn Easily
    Computer Shut Down; Control Boards Still On; Pullies Locked
    Any ideas ? Thank You.
    Bob
    Oct 2013
    24
    Those symptoms sound like the boards are being disabled when Mach 3 starts. Do you have the EN+ and/or EN- connection on the TB6600 connected? If so, remove them on one of the motor controllers and see what difference that makes.
  1. TB6600_T4 Problems
    By rfhall50 in forum DeskCNC Controller Board
    Last Post: 04-21-2020, 05:52 PM
  2. Replies: 11
    Last Post: 01-14-2020, 11:59 AM
  3. THC not going down and other problems
    By K-Rigg in forum Mach Plasma / Laser
    Last Post: 02-17-2011, 09:37 PM
  4. Problems
    By vebers in forum Servo Drives
    Last Post: 05-03-2006, 05:59 AM
  5. 85 vmc 40 problems
    By tractdesign in forum Fadal
    Last Post: 01-17-2005, 11:15 PM
