586,375 active members*
3,436 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Simphoenix/Sunfar E550 VFD with HICON Integra 7866 and Mach4 Help needed
    Dec 2019
    I switched from a xulifeng Motion control and Mach3 to a HICON Integra 7866 with Mach4.
    My VFD is a Simphoenix E550
    I can not get the VFD to work no matter what I try.
    The old board used PWM, ground and X1 (Forward) outputs. New board uses 0v-10v analog. I can operate the VFD from the keypad. I have checked voltage readings from the 0v-10v output on the card and MDI differents speeds and voltage from the card looks good.
    Going through the VFD manual though, I am unclear as to what connections it needs vs the old setup.
    I have GRD, 0v-10v analog and X1 connected. And I get nothing when I MDI any speed but
    If someone can offer assistance, I will gladly pay for some tech support here!
    15362
    Re: Simphoenix/Sunfar E550 VFD with HICON Integra 7866 and Mach4 Help needed
    Quote Originally Posted by Gkinkaid View Post
    You need to connect the 0-10v to the VS and GND
    For On / Off X1 and CM
    You will need to set the Parameters for remote control also, so if you are able to use the KeyPad, then these connections will not work when this is set correct the KeyPad will not work
    Mactec54
