586,058 active members*
3,307 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Help to connect Universal MPG from China to UNCNC with UC100
    Sep 2016
    I had a cheap usb pendant from China for Mach3 that worked great on my system (UCCNC and UC100). One of the switches is dying and I found a 4 Axis Universal MPG Hand Wheel Pendant that requires the wires be connected to a BOB. I have a bob between my xylotex box and the UC100 that I thought I could connect this pendant to but don't know which pins the wires connect to. Can anyone help?
    Line color definition
    colour signal
    red Vcc
    black GND
    green A
    white B
    purple A\
    purple\black B\
    yellow X
    yellow\black Y
    brown Z
    brown\black 4
    pink 5
    pink\black 6
    gray X1
    gray\black X10
    orange X100
    orange\black COM
    green\black L+
    white\black L-
    blue stop-c
    blue\black stop-cn
    Mar 2020
    27
    Re: Help to connect Universal MPG from China to UNCNC with UC100
    Hello, I am from WEIHONG, our company supplies cnc controller. If you want to change a controller please contact me.
    [email protected]
    Sep 2016
    Can you answer my question?
    Aug 2007
    18
    Quote Originally Posted by Harnell View Post
    You said your old pendant was USB, so it only transmitted a data signal to a plugin for all that functionality and all those buttons.
    For your new pendant, technically you can wire each of those signal wires on your new pendant up to a BOB and set them in UCCNC, but they each take an input, which means that the UC100 isn't appropriate to use with that pendant, but something like the UC300 with lots of IO would be.
    Sorry, but your out of luck with that pendant to work via a UC100.
    Eric
    May 2015
    686
    It would also work nicely with Linuxcnc but as said it would still consume a lot of pins. I use something similar. Something like a Mesa 7i76e would do it (32 inputs, 16 outputs, 2 MPG inputs).
    Rod Webster
    www.vehiclemods.net.au
  1. UC100
    By naijin in forum Australia, New Zealand Club House
    Last Post: 02-01-2016, 04:04 PM
  2. Replies: 0
    Last Post: 11-27-2012, 04:19 PM
  3. Universal Cutter Grinder - China Supplier?
    By robbec in forum Chinese Machines
    Last Post: 10-22-2011, 09:44 AM
  4. (SyiL China)will participate in the 107 session of China Import and Export Fair
    By syil in forum Trade Shows / Webinars / Other Events
    Last Post: 02-26-2010, 01:28 AM
