586,036 active members*
4,350 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang settings for 300hz air cooled spindle
    Feb 2013
    81
    I see lots of setting for the 2.2kw 400hz spindle but i’m after the Huanyang settings for a 1.5kw air cooled spindle.
    Spindle spec
    Voltage 220v,
    Current 6.5A 3 Phase
    Frequency 300hz
    Speed 0-18000rpm
    I’m mostly going to be running this between 6000-8000 rpm milling foam but just occasionally I need to run it at 2750rpm, which is not ideal as the internal fan is only operational above 100hz but for a 15min mill in foam should be ok. In hind site I should have bought a water-cooled one but there we are.
    Anyone got a nice Huanyang setting chart for this spindle?
    Feb 2013
    81
    Re: Huanyang settings for 300hz air cooled spindle
    I've set PD005, PD004, PD003 and PD072 all to 300hz. Some of the others are stumping me a bit
    PD001 1
    PD005 300
    PD004 300
    PD003 300
    PD006 2.5 ?
    PD008 220
    PD009 15 ?
    PD010 8 ?
    PD011 100 ?
    PD072 300
    PD0142 6.5 ?
    PD0143 ?
    PD0144 2250 ?
  1. Inside Huanyang 2.2k Spindle GDZ-80-2.2B Water Cooled
    By raptor_demon in forum Chinese Machines
    Last Post: 08-14-2021, 11:03 PM
  2. Replies: 8
    Last Post: 07-03-2021, 09:02 PM
  3. Replies: 67
    Last Post: 07-29-2020, 02:22 PM
  4. Pulley min/max for Huanyang VFD and air cooled 2.2kw spindle
    By chrishallowell in forum Spindles / VFD
    Last Post: 12-14-2016, 02:39 PM
