586,102 active members*
2,511 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Question about adapter and taps in floating holder
    Apr 2015
    26
    Our shop has a Parlec floating holder with a Bilz adapter, holding a roll forming 10-32 for aluminum parts. I've used this alright for a while, but now having problems with the tap pulling out of the adapter (It then stays in the hole and breaks off when the machine goes to the next hole location.)
    The taps I'm using have a very slightly "ridged" surface on the square drive portion, which I am now thinking/realizing is there to help the balls inside the adapter grip the tap. When I switched to a different brand of tap I happened to have with much coarser ridges, it didn't pull out as often as the others did.
    First of all, I'm wondering if I should just replace the adapter - maybe the spring pressure on the balls has weakened (Although, it seems plenty hard enough to compress the ring when installing a tap.). Does anyone have a preference/recommendation of getting a new Bilz adapter over a Parlec, or another brand?
    Secondly, do any of you guys make a point of buying a particular brand of tap because it is made with deeper ridges on the square drive (So it holds better)? If so, what is it?
    Jun 2015
    4154
    Re: Question about adapter and taps in floating holder
    hy, my guess is that those ridges, if not positioned properly, will make the balls slip, thus you will lose grip, making the tap rotate for a bit
    if you have taps that last much longer, then use a marker to dye the area, and compare with those that don't last so much
    if you are lucky, then is the ridges ... otherwise, maybe the blizz is starting to get wear / kindly
  1. Floating Reamer Holder
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 03-21-2019, 02:45 AM
  2. Need Floating Tap Holder For CNC Lathe
    By WarOzz in forum CNC Tooling
    Last Post: 11-25-2011, 01:09 AM
  3. Anyone use a floating tap holder for 4-40 in 6061?
    By petriej in forum MetalWork Discussion
    Last Post: 08-05-2009, 11:19 PM
  4. Pulling taps out of floating holder
    By cam1 in forum MetalWork Discussion
    Last Post: 04-02-2008, 05:54 PM
  5. Floating pen holder
    By jrc347 in forum Torchmate
    Last Post: 03-27-2008, 02:27 PM
