586,065 active members*
4,476 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V30 rotary 4th axis drilling wont rotary..... lol
    Aug 2010
    188
    Good morning All,
    i have a part set up in my okuma MA650 with OSP200M control. the part is set up in a rotary 4th axis, with the rotational axis being parallel to x. i need to drill some holes about the outer diameter at misc degrees of seperation.
    now, when i try to start a drilling operation in BobCAD, i follow all the steps from the tutorial videos (select cross drilling/select axis of rotation/ect), only geometry that lines up perfectly with my z axis is able to be selected, in this case, 2 out of the 80 holes that actually need drilled. what am i missing?
    Attached Files Attached Files
    Jun 2008
    1838
    Re: V30 rotary 4th axis drilling wont rotary..... lol
    Think you should be selecting "Multiaxis Drilling" instead of the "Cross Drilling", seems to work here OK, see image
    Hope this helps
    Regards
    Rob
    Aug 2010
    188
    i had tried that last week and it didnt seem to work, must have been doing something different, seems to be working today....
    i also had errors in my retraction setting that were making it act funny, had to change the rotational indexing axis from Z to X, and from plane to cylinder..
    anyways, thank you for your reply, i should be good to go now!
  1. Drilling holes on a cyinder face with rotary axis
    By ZeroBacklash in forum Uncategorised CAM Discussion
    Last Post: 01-23-2019, 07:32 PM
  2. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  3. Drilling holes in x-y plane on rotary table
    By GTOGuy in forum Mastercam
    Last Post: 09-06-2015, 03:39 AM
  4. Replies: 1
    Last Post: 01-14-2012, 06:22 PM
  5. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
