586,068 active members*
3,896 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > 1337/5000 TNC155: Data in RAM but inaccessible
Results 1 to 6 of 6
    Aug 2011
    11
    I have removed the batteries and cleared the RAM.
    When turning on the CNC, the message appears: "OPERATION PARAMETERS ERASED"
    I press EXT and the screen goes as in the photo, so far so good
    But, when I want to enter a value, what I type does not appear in the parameter value field, the "?" still comes out.
    If I enter a wrong value it warns me.
    If I put all the parameters on the keyboard or downloading from the PC, they are saved, I turn off the CNC, turn it on and everything is fine but when trying to edit them the same thing happens, that the list does not appear, only one parameter appears and with a value "?" and go to the parameter that goes exactly the same.
    If someone could help me, they will appreciate it very much.
    May 2016
    526
    Re: 1337/5000 TNC155: Data in RAM but inaccessible
    If you type in the correct value and press ent does the value change
    When you're accessing them do you put in the unlock code
    Aug 2011
    11
    Thank you very much for answering
    I enter code 95148
    If in P01 I enter a correct value (when I am typing the numbers the "?" remains in the value) and I press ENT the parameter goes to P02 which also has the "?".
    If I go back to P01 it continues with the "?".
    If I entered an incorrect value I would get the message "INCORRECT VALUE ENTERED"
    May 2016
    526
    What happens if you load all parameters then reboot system
    Aug 2011
    11
    The list of parameters does not appear, only one parameter appears and with a value "?"
    May 2016
    526
    Your batteries have failed
    When the parameters are loaded they would come up with a ? You would not be a me to go back it would come up with a ? Again
    Unless all the parameters are fully loaded
  1. Retrofit Prolight 5000 (Benchman 5000) to run Mach
    By Impyman18 in forum Benchtop Machines
    Last Post: 07-10-2019, 04:12 AM
  2. TNC155
    By DOMTEK in forum PTC Pro/Manufacture
    Last Post: 06-17-2019, 11:06 PM
  3. mc9 post for tnc155
    By G00 in forum Post Processor Files
    Last Post: 06-22-2015, 02:52 AM
  4. Hiedenhain TNC155
    By SOLIDCAMSTEVE in forum Machinery Manuals / Brochures
    Last Post: 05-12-2013, 06:29 AM
  5. Bridgeport TNC155 with EMC2?
    By dbcooper99 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-15-2007, 09:34 PM
