586,105 active members*
3,215 visitors online*
    Jul 2015
    20
    Boss 5/6 short in Z-axis power
    Have a Boss 5 Bridgeport (RigidRam) that is blowing fuse 17, which is the feed to the z-axis rectifier. After the rectifier are 2 capacitors and a resistor that that smooth out the rectifier output ( the capacitors) and dump the capacitor charge when the power is shut down ( the resistor). Right after the caps and resistor is fuse 14, which does not blow, telling me that everything down line from that fuse is OK (fuse 14 is 10 amps, fuse 17 is 15).
    The caps, resistor, and rectifier all check out as good ( the caps and rectifier are out of the machine - royal PITA job!), which would lead me to believe that the line from fuse 17 to the rectifier is shorted, but so far it tests out OK - no connection to ground anywhere (tested with the wire unplugged from the rectifier).
    However, while the resistor seems to check out OK ( by taking a reading from the correct terminals in the terminal block), I would like to look directly at the resister itself, but cannot find it in any of the manuals (lots of components are not shown in the manuals!).
    Does anyone familiar with those controls know where that resistor is mounted? I would think that the resistors for all 3 axis would be grouped together.
    Also, do you know what the SMS board controls? Have a broken ceramic resister there (z-axis again, as well as a blown fuse). Again, no mention of it in the manuals!
    Jul 2015
    20
    Re: Boss 5/6 short in Z-axis power
    Well, I figured out what the SMS board does ( dampens back emf if an axis stops abruptly), so that has nothing to do with this fuse blowing. With everything checking out as good, my guess now is that a chip or some carbon dust was the culprit ( the machine gets used a lot to machine carbon/carbon brake pads), so it's time to put it all back together and see if the problem has gone away.
    Still cannot find those resistors!
    Dec 2006
    87
    i have a couple of the rigid ram boss' and a couple of the boards left if you need them.. for the most part gutted the controls to upgrade them
    Jul 2015
    20
    Quote Originally Posted by mongoose View Post
    Thanks. Have quite a few spares of all the drive boards already, most left over from the sister machine that eventually will get the Mach 1 control on it that has been here for 5 years, and once that one is up and running, this one will get converted as well.
    So, no one knows where those particular resistors are located?
  1. z-axis stopping short during workpiece zero-ing
    By straydogg in forum Tormach Personal CNC Mill
    Last Post: 06-15-2016, 12:08 AM
  2. Replies: 2
    Last Post: 09-27-2015, 03:41 PM
  3. dual drive on short axis
    By jakkefire in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2015, 03:33 AM
  4. Interact 1 mk2, No power to Heidenhain 151 B Mains After Coolant Pump Short
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2012, 03:29 PM
  5. short power cut during program run
    By motoRacing in forum SERVICE FOR CNC-MACHINES
    Last Post: 09-07-2011, 02:03 PM
