586,103 active members*
3,453 visitors online*
Results 1 to 7 of 7
    Sep 2013
    131
    Harmonica Reed Plates
    Hi everyone, I have a harmonica design and I'm not sure of the best way to make the reed plates. Some kind of press, a very small endmill maybe to cut through .050 brass with minimal corner rads. Any ideas would be great.
    Apr 2004
    5737
    Re: Harmonica Reed Plates
    I'd suggest making a set of cutting dies out of tool steel and hardening them after machining them. You'd use them in a hydraulic press. You'll probably need to square the inside corner radii with a file, but the rest shouldn't be a problem to mill out.
    Andrew Werby
    Website
    Sep 2013
    131
    Yes, I was thinking that also, but with today's technology I was hoping for a quick process ha ha. Thank you Andrew.
    Apr 2004
    5737
    I suppose you could print them directly in metal. That would be quick, but co$tly...
    Andrew Werby
    Website
    Jan 2016
    120
    I believe fiber lasers will cut brass. Are the parts bent afterwards? If so, a cut/bend tool on a press is probably your best bet.
    Apr 2004
    5737
    I don't think they're usually bent. The fiber laser should work, or an abrasive water-jet machine, if the spot size is small enough.
    I'm not sure any of these processes are things you'd realistically set up for your own home workshop, but there are companies that will do them for you. Probably the best method would be spray-etching: https://microphoto.net/services/phot...iAAEgJ1w_D_BwE
    Andrew Werby
    Website
    Sep 2013
    131
    Thank you guys for the thoughts on this, there is an upper and lower plate and my design is to have holes 2 thru 6 and spread apart for easy single notes for blues playing. The holes can be made on a drill press but the slots are the trick.
  1. Laser cutter for Aluminum plates and Acrylic plates in one machine
    By Yordanu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-29-2015, 12:20 PM
  2. Is my air compressor stuffed? How to fix? Reed valves???
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 09-23-2010, 01:52 PM
  3. Harmonica parts anyone?
    By LN-JET in forum Musical Instrument Design and Construction
    Last Post: 11-29-2009, 01:55 PM
  4. Harmonica cover plates
    By swarfmacdaddy in forum Moldmaking
    Last Post: 04-16-2008, 08:20 PM
  5. reed valve
    By superrotary in forum I.C. Engines
    Last Post: 09-27-2007, 10:24 PM
