586,111 active members*
3,225 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Journeyman 325 Tree Mill
    Oct 2016
    14
    Our Journeyman 325 with allen bradley 9 control intermittently drops the tool during machining cycle
    we do not know if we have type 1 2 or 3 spindel
    Oct 2006
    60
    Re: Journeyman 325 Tree Mill
    Look up in the taper. Rev 3 has collet with 6 balls and 6mm Allen screw in middle. Rev 2 has a collet with 3 balls and a knock-out button in center past the taper. Rev 1 has 6 pins, 3 each on two different levels past the taper. We rebuild them all. [email protected]
    Oct 2016
    14
    Thank you we will check it out
    Oct 2016
    14
    the was metal chips up inside the collet so we are hoping now its cleaned the tool will not pop out now
    Oct 2006
    60
    Good luck. Shoot me an email if you need anything else!
    [email protected]
  1. Journeyman 325 tree mill retrofit
    By ramsey321 in forum Tree
    Last Post: 09-25-2020, 03:18 AM
  2. USA: WTB Tree Journeyman or other small CNC mill
    By rallyx99 in forum Want To Buy...Need help!
    Last Post: 09-21-2018, 03:03 AM
  3. Journeyman 325 tree mill
    Last Post: 08-10-2010, 10:19 PM
  4. Replies: 0
    Last Post: 05-21-2007, 01:34 AM
