Hey there,
I did some research and found that this should be doable. I went and bought some 1/32" silicone rubber (the red stuff - https://www.mcmaster.com/1460n11-1460N113) which was the recommended material, but I'm having trouble actually cutting through it.
I'm running a 40W laser with a 2.5" focal lens. I'm down to 4mm/s cut speed and it still won't go through at full power. I've fiddled with my focus and I'm pretty sure i have that nailed down. I tried swapping my compressor with a higher PSI air compressor and that didn't make much difference either.
The result I'm getting is that the laser is burning maybe halfway through it then stopping. There appears to be a lot of charred material caught in the cut and so I assume the laser isn't able to cut deeper with the soot there. I don't think I can remove that soot manually (brushing it or wiping it) as it would throw off my positioning and I wouldn't be able to do a second pass on it.
Here's what my test cuts look like: https://i.imgur.com/dgEuyBm.jpg
The couple square that are popped out are ones that nearly cut through but I had to rip in order to remove. The 16 squares on the left are testing various speeds and # of passes, none of them worked. The assorted squares on the right section are various tests of different focal calibration and increase airflow.
I have an 80W tube replacement ready on hand, but I was hoping to finish delivering some gaskets before putting the machine out of commission while I make the swap.
Any ideas on other things I can try or should I just hurry up and swap my tube to get this done?
