586,043 active members*
3,669 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Z Level Rough not going full depth
Results 1 to 18 of 18
    Aug 2005
    176
    I'm still learning and can't figure out why the Z Level Rough is not going full depth on the top cut of this block
    Appreciate you help. File attached
    Rob
    Re: Z Level Rough not going full depth
    I've same question in V32 using Advanced Rough -> Adaptative Roughing:
    How you can see the toolpath don't reaches the 3D faces.
    Attached Files Attached Files
    Aug 2005
    176
    Quote Originally Posted by shineworld View Post
    1. You should see the cut line in simulation on bottom surface
    2. I can the part and it will only cut to .200 instead of .25
    I changed the cut depth to .250 and it won’t simulate.
    Jan 2018
    1516
    I don't know about your cam program but in the one I use there is a checkbox somewhere for 'rough final' that needs ticking which does it for me.
    Or also as a default mine also checks 'stock to leave' of 0.5mm automatically which affects it not reaching bottom of part.
    This either needs unchecking or me to create an extra program for a final finish.
    Aug 2005
    176
    No , There isnt anything like that
    Dec 2008
    4548
    Quote Originally Posted by artracing View Post
    I made some videos a few years ago that gets into what and why of what you are describing.
    Basically the zlevel rough is going to calc off the "Material to be removed", with the surface as a guide, as opposed to the "Surface to be cut"....
    Does that make sense to you? if you think about it, you can put it together....
    Do you want a link to the videos?
    Aug 2005
    176
    Quote Originally Posted by BurrMan View Post
    Link would be nice.
    I selected the bottom edge to cut but still doesn’t work. So I guess I’m confused.
    - - - Updated - - -
    Quote Originally Posted by dazp1976 View Post
    I attached the file if you want to run it and see.
    Dec 2008
    4548
    Was just 1. Hope it helps.
    https://youtu.be/aGDzFzqnvZU
    Jun 2008
    1838
    Really odd, does seem to work if the stock is set as square or rectangular and greater than the diameter of the part ??????
    Or if round stock and using a 10mm Diameter tool then you need to have a stock offset equal to or greater than the tool diameter
    Major "BUG" ????????????
    Regards
    Rob
    Aug 2005
    176
    Thanks , But i don't think this is my case
    If you run my file you will see.
    its 3.5" block. I'm cutting .25" deep.
    It only goes .2 "
    You can see it in the model and I ran it on my machine.
    Jun 2008
    1838
    It only goes .2 "
    I can`t run your file, I only have V31 demo so it won`t open your file as it is a later version you have.
    I have tried to replicate your issue in V31 but apart from what I posted earlier I have nothing else for now.
    I will try to replicate it in my V28
    Regards
    Rob
    Aug 2005
    176
    Yes, I'm using 32.
    Where is BC techs here. I think this is a bug. But then again , i just might be doing something right.
    Dec 2008
    4548
    So like this, where it goes to .25 deep on this surface????
    Attachment 441780
    Dec 2008
    4548
    Yes, I'm using 32.
    I could make a video, or just tell you here.... (If that picture is it)
    Dec 2008
    4548
    Fancy Video... Watch out for the bad audio. Havnt used a Mic in awhile. Kindof blown out..
    https://youtu.be/n9l2zkUWxpQ
    Dec 2008
    4548
    To the top!
    Dec 2008
    4548
    Back to the top again!
    Aug 2005
    176
    Thank you for that. It was very helpful. It gave me a solution to my problem but appears there are issues that are now bugs.
    I removed the allowance and it worked.
    1, That says I can't leave a finish allowance?
    2. Change the cut depth to .100 will only allow .200 cuts but leaves .050 uncut
    3. GO back ,125 depth and it cuts the full .25
    4. Set allowance to .0001 and it wont do the second cut.
    5. The only way it cuts the full .250 , the depth must be set a even multiple, or it won't make the last cut.
    This sounds like a bug to me.
  1. Z Level Rough Vs Z Level Finish
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-19-2016, 03:37 AM
  2. V24 z level rough boudary
    By Ben S in forum BobCad-Cam
    Last Post: 11-28-2013, 01:46 PM
  3. Z Level Rough
    By fidia in forum BobCad-Cam
    Last Post: 01-05-2013, 06:19 PM
  4. Problem milling Z-Level rough
    By JHren30 in forum BobCad-Cam
    Last Post: 02-07-2012, 07:58 PM
  5. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-26-2010, 05:45 AM
