586,497 active members*
2,726 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > a simple live tooling attachment to a CNC lathe
Results 1 to 9 of 9
    Feb 2006
    120
    it has been a while since I have posted. so I figured that its about time I be a bit more active.
    I decided I needed a live tooling spindle on my lathe, my concept is that it will be mounted on a 1 inch quick change tool post. It also needs to run a 5/8 HSS cutter on steel. that would give me a spindle RPM of about 500, I happen to have a large closed loop stepper motor lying around that would do nicely. I decided to cast the housing out of aluminum, it is soft enough to make for a very solid connection to the QC toolpost. I have some very cheap angular contact bearings.They are standard size though, so if they become a problem, I will change them out for a higher quality bearing. (Each bearing might have cost me $2.00) currently I am running DA100 collets on a BT40 holder, in my CNC mill, so I machined the spindle to accept those collets too. pictures will follow.
    Ray,
    Life is a choice, death is choice poorly made.
    Feb 2006
    120
    Re: a simple live tooling attachment to a CNC lathe
    The design starts with the spindle casting, I modeled it with fusion360, then 3d printed it, I used the 3d printed part as a pattern to sand cast it. it was the first time I used a 3d printed part as a pattern, it worked really well. the coupling from the spindle is not yet made, it is designed as a general mount for the motor in other project, I am just reusing it here.
    Ray,
    Jan 2006
    114
    Nice work, alsoo good pouring.
    Are you using greensand or petrobond?
    Are you melting the aluminum with an electrical oven?
    Pierke
    Feb 2006
    120
    thanks,
    I used petrobond, with an electric furnace. this picture is from the melt on this project. I have since fixed the element that fell from its groove.
    Ray,
    Jan 2006
    114
    Hello Ray,
    whats the power of the elments 3 -4000 watts?
    how many hours to meld the aluminum?
    Pierke
    Feb 2006
    120
    there are two elements, totalling 2600W I have a furnace controller on it too in order to control the maximum furnace temp. I am not usually in a hurry, but I think it takes about two hours to melt 6lbs of aluminum and prepare for a pour.
    Ray,
    Jan 2006
    114
    Hello Ray,
    2.72 Kg in two hours, thats nice. The furnace controller is one with an K-sensor or Pid ?
    I'am looking for Petrobond (Brusslese aarde) hier in my nabor, and give Pouring a try this summer.
    Thanks for your explanation,
    Pierre
    Feb 2006
    120
    the heating elements are Kanthel 110V 1600W each, the furnace is fairly well insulated with light firebrick, I am using a heavy duity exposed K type Thermocouple, the elements are controlled with a solid state relay by a PID Temperature controller. I currently use the furnace primarily for heat treating steels. a PID temperature control isnt neccesary, but its nice.
    Ray,
    Jan 2006
    114
    Hello Ray, thanks for dealing this knowledge.
  1. CNC Lathe w live tooling??
    By cloud chaser in forum RFQ (Request for Quote)
    Last Post: 07-09-2011, 04:17 AM
  2. MAZAK Lathe Live Tooling G41 EIA
    By ammfg in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-29-2010, 06:33 AM
  3. live tooling on a lathe
    By kkronja in forum PTC Pro/Manufacture
    Last Post: 03-12-2010, 07:13 AM
  4. Lathe live tooling as spindle?
    By sergizmo in forum Benchtop Machines
    Last Post: 08-28-2008, 11:03 PM
  5. Lathe with live tooling
    By baldysm in forum Uncategorised CAM Discussion
    Last Post: 12-27-2007, 05:28 AM
