I'm looking into cutting a fusee on my lathe, but none of the available gcodes seem appropriate to do this.
A fusee is just a thread that is cut along a curvy profile, unfortunately, synchronised G32/G33 codes are not set up to do anything but linear moves and so can not be used.
A G95 feed-per-rev gcode would be ideal, except I don't think it is synchronised between passes.
So the question is: Am I missing a trick, or if not, would it be possible to add a 'synchronised between passes' function onto the G95 gcode?
Many thanks.
Martin.
