586,069 active members*
3,797 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Doosan Puma 480 Rapids
    Apr 2020
    We have run into a problem on one of our Puma 480’s, it seems that our G00 rapid and our G94 seem to have mixed themselves up as in the case of the rapids it seems to be moving using a slow feed whereas when we use the G94 facing cycle straight after it it runs as a rapid feed. Now it ran fine on the 1st part but this happened on the 2nd part. Apparently something similar happened before a few years ago on the machine where instead of moving quickly in the G00 rapid it fed out at a slow feed at the end of the program. Has anyone ever come across this problem before?
    May 2020
    Re: Doosan Puma 480 Rapids
    Did you fix this problem? I think you should consult the experts! bullet force
