586,655 active members*
3,982 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak FJV250 with 2APC (Fusion 640M)- 331 PALLET LOAD\UNLD DRIVER ALARM
    Aug 2014
    Question Mazak FJV250 with 2APC (Fusion 640M)- 331 PALLET LOAD\UNLD DRIVER ALARM
    Dear Sirs,
    After transportation to another place have trouble with APC.
    on MR-J2-CT on LOAD Z70 0002 ABS/ reference point disappearance.
    Test mode - Illegality.
    Tried to fix by "ABS Pos. Repair" after system restart, the same alarm.
    What is wrong and how to fix it?
    Will be grateful for any help!
    Sep 2017
    139
    Quote Originally Posted by Ievgen View Post
    Dear Sirs,
    Is the drive battery voltage okay?
    If yes the backup the drive data.. Format and initialize the drive.. Reload the data and then try abs pos setup
    Aug 2014
    Re: Mazak FJV250 with 2APC (Fusion 640M)- 331 PALLET LOAD\UNLD DRIVER ALARM
    The battery voltage okay. I will try. Thank you for advice.
    Nov 2020
    13
    Lol: First check battery. If its good, then off on the machine, to get the drive into zero lost mode. Then setup zero point using MRJ2SW(u need to know where is your electrical zero and how to setup using MRJ2SW). Thats all.
  1. mazak fusion 640m 4th axis rotation limit
    By kevinlupson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2019, 11:10 PM
  2. Mazak FJV250 with 640M Control
    By 9566317 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-31-2017, 05:10 PM
  3. Mazatrol Fusion 640M, Alarm 249
    By Rocketnsam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-31-2016, 12:24 PM
  4. Mazak Mazatrol Fusion 640m- FH6000 - Alarm 391
    By riddmj in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-23-2011, 07:42 AM
  5. 1999 Mazak FJV-250 with Fusion 640M Control
    By Hastx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-11-2010, 04:42 PM
