586,359 active members*
3,557 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Fanuc a/3000 Sevo and GraniteDevices Drive
    Dec 2007
    578
    Hello,
    Got a 4th axis that has a Fanuc redcap servo. Currently trying to see if the Granite Devices Argon drive will work. What i have so far is drive connected and setup within the Granity software.
    Currently motor will only snap to a pole position if it is near a pole when testing with Granity Jogging in Torque Mode. If motor is already at a pole position it will not rotate, just holds at my peak current of 4.6A. Has anyone succesfully tuned an alpha Faunc servo to work with a Argon? Or maybe another drive?
    I have adapted a USDigital Incremental encoder with 2000ppr to the servo.
    Attached servo motor plate.
    Thanks for any info,
    Troy
    Dec 2007
    578
    Re: Fanuc a/3000 Sevo and GraniteDevices Drive
    Got something working Needed to invert the feedback direction in the Granity software. Encase someone else ventures down this road here is my settings so far.
    Troy
    Attached Thumbnails Attached Thumbnails Machine1.jpg   Goals1.jpg   Fanuc_a_3000graph.jpg
    Attached Files Attached Files
    Jan 2014
    126
    Which US digital encoder did you use? How are you handling motor commutation?
    Dec 2007
    578
    Number of encoder is HD25-2000-N-N-L-IE-D
  1. MultiCam 3000 Xa servo drive motor
    By albox in forum Multicam Machines
    Last Post: 04-27-2022, 04:21 PM
  2. Replies: 0
    Last Post: 01-28-2013, 12:55 AM
  3. Sevo motor with omron drive
    By asmvn in forum Servo Motors / Drives
    Last Post: 01-10-2011, 02:23 AM
  4. teknic sst 3000 servo drive
    By john.charles in forum Servo Motors / Drives
    Last Post: 12-20-2010, 07:28 PM
