586,103 active members*
3,703 visitors online*
    Jul 2009
    11YO board, no instructions
    I bought a 4-axis CNC motor kit from Rockcliff in 2009, and promptly put it on a shelf and forgot about it.
    I always meant to get around to doing something with it, and now is that time. 11 years later.
    I'm going to put a 2'x4' table together out of aluminum extrusion and connectors, but the problem I have is that I can't find the instructions that came with the board.
    I'll make a followup post with a labelled picture and the information I'd like.
    Jul 2009
    Re: 11YO board, no instructions
    1) POWER INPUT - Obviously positive and negative, but how much?
    2) WIRE CONNECTOR BLOCK - Not sure of these at all. I imagine that some are for Estop and limit switch connections.
    LPT1 GND
    10
    11
    12
    13
    14
    15
    16
    17
    X
    Y
    Z
    A
    COM
    3) XYZA ENABLE - I'm planning to run this with A mirroring X. Assuming I leave all the jumpers on to keep them enabled. Duh.
    4) A-, A+, B+, A- connectors and MS1, MS2 jumpers - I imagine these are connected to the NEMA23 motors.
    5) X_CUR, Y_CUR, Z_CUR, A_CUR pots - Not sure what these are for.
    The kit came with this motor driver board
    4x NEMA23 270oz/in hybrid motors
    6' parallel cable
    24V DC @ 6.5A power supply selectable 120/240V AC
    I know that there are a few really simple solutions out there using Arduino UNO boards with CNC hats, and I might eventually try that if I can't get this to work.
    I already have this, so I'd like to try to use it.
    Just saw this, I have the manual as a PDF if you still need it.
  1. no instructions
    By DadaVinci in forum Australia, New Zealand Club House
    Last Post: 01-15-2018, 11:38 PM
  2. Mechatronics 4axis Bipolar board-instructions/configuration
    By metalworkz in forum Controller Cards
    Last Post: 01-28-2017, 06:33 PM
  3. LG 500 instructions
    By scotty c in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-30-2013, 12:04 PM
  4. Need instructions for new DSP
    By danielcoyle in forum Controller & Computer Solutions
    Last Post: 05-20-2013, 12:57 AM
  5. better instructions
    By henryj1951 in forum Jewelry Design Software
    Last Post: 02-19-2009, 09:19 PM
