586,108 active members*
3,269 visitors online*
Results 1 to 10 of 10
    Mar 2017
    14
    Hurco ATC problem
    I have a BMC-2416, I am having an issue with my ATC. The tool pocket won't come down through the control or on a tool change. When I actuate the manual override on the solenoid everything works as it's supposed too. I rewired the connections from the junction box and the tool changer control solenoid after finding some nicks in the wire insulation. Does anyone have any ideas on what to look at next? Or what the part number for the solenoids are so I can track down some diagnostic info on testing them.
    Apr 2019
    58
    Re: Hurco ATC problem
    Write email i send you instruction manual
    Išsiųsta naudojantis SM-G960F Tapatalk 4 Lt
    Mar 2017
    14
    I sent you a message good sir thank you!
    Apr 2019
    58
    [email protected]
    Mar 2017
    14
    Alrighty I shot you an email
    Mar 2017
    14
    Thank you hopefully the answers are in there!
    Mar 2017
    14
    Unfortunately I don't see a lot in there regarding the tool pocket down.
    Apr 2019
    58
    Then maybe try check soilenoid. Tage tubes off. And manual switch down then up. Maybe pressure to low. Or it is dameged.
    Mar 2017
    14
    Manually switching them works, i.e hitting the bypass buttons on the solenoid. It looks (right now at least) like the solenoid isn't getting any power
    Apr 2019
    58
    In there iswiring chexk 24 vdc.
