586,065 active members*
4,327 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Config Aggregate in Biesse 321,322 CNI controller
    Apr 2006
    512
    Does anyone no how to config an aggregate (see photo). Its to go in a 4th axis Biese 322. The config should be the same for any CNI controlled Biesse.
    Apr 2018
    37
    Re: Config Aggregate in Biesse 321,322 CNI controller
    You'll need to find out which Aggregate number it is, then select that in the aggregates window, then define the correct parameters which will be slightly different to what is already preset in each field.
    This is the aggregate PDF.
    Apr 2006
    512
    Thanks for PDF. It looks like the nearest equivalent is 22. I have managed to sort out the Gcode. I am just not certain on the Configuring the machine for an aggregate. Have you setup an aggregate yourself, and would it be possible to show your setup screens?
    Apr 2018
    37
    Quote Originally Posted by bigz1 View Post
    No problem.
    So you aren’t using BIESSEWORKS, I’m not familiar with anything other than XNC and BIESSEWORKS.
  1. Replies: 8
    Last Post: 03-07-2021, 06:48 PM
  2. Biesse rover 346 CNI RT480 Tool setup of aggregate
    By kpq in forum CNC Machining Centers
    Last Post: 04-26-2019, 09:09 AM
  3. Replies: 1
    Last Post: 08-29-2018, 12:22 AM
  4. Mach3 config file for High z s-1000/T model with new Zero3 controller
    By madeinwood in forum Commercial CNC Wood Routers
    Last Post: 10-30-2017, 11:46 PM
