586,115 active members*
3,494 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 3016 control slowing up and needs to be reset often
    Weird issue that started ocuuring on our 3016L AC -5 machine. maybe someone can enlighten me. After a half day the machine suddenly doesn’t take my cd, dir, at commands and sits doing nothing. If I change to jog it slowly moves to the jog screen opening a numeral at a time or if menu opened it takes 2 minutes to load the menu page and I can no longer use the machine without shutting down and restarting. its basically like a laptop when it freezes during a render and you can’t do anything. The control cabinet felt warm but no errors of any kind. Any idea what may be going on?
    Oct 2008
    1632
    Re: 3016 control slowing up and needs to be reset often
    No idea if yours is for the same reason but, are you running a Calmotion USB box? If so, go reboot it by removing the power to the box for a few seconds then reconnecting.
    Mine will do the same thing, and once I reboot the Calmotion box all is fine.
  1. Replies: 5
    Last Post: 11-16-2018, 01:12 PM
  2. Robofil Control Reset when Turn On Injection Pump
    By mflux_gamblej in forum EDM Discussion General Topics
    Last Post: 02-22-2018, 08:51 AM
  3. How do I reset a Fanuc 2000C control?
    By Fadal Error in forum Fanuc
    Last Post: 09-14-2010, 04:17 AM
  4. tutor for fadal 3016 w/ 88 control
    By Runner4404spd in forum Employment Opportunity
    Last Post: 02-25-2009, 10:13 PM
  5. On an OT control, hitting the reset button
    By g-codeguy in forum Fanuc
    Last Post: 06-14-2007, 05:21 AM
