586,075 active members*
3,886 visitors online*
    May 2013
    49
    PP din socket for tool setter
    PP din socket for tool setter.
    I have a tool setter non Tormach but looks the same mine does not have a led only to switches one for the tool trip and the other NC for the over travel fault.
    I am looking for the connections to this DIN socket for the two switches. I believe pin 1 is 5v dc - pin 4 is common - pin 2 not used - pin5 input - pin 3 is 12v dc
    May 2015
    111
    Re: PP din socket for tool setter
    This is the schematic for the 1100m
    May 2013
    49
    Thanks for the info. My machine only has one Din socket. I would have thought that the Tormach setter would have a safety second switch in case the first one fails for some reason
    The same socket is used for different probes
    So I am looking for the correct pins on the din socket to put the switch across
    Oct 2017
    62
    Quote Originally Posted by Clive S View Post
    Millfast Products advertises adapters that allows two devices to be installed. Depending on the model, they have one for 2 NO switches and a NO/NC version.
    May 2013
    49
    With further investigation the pins to use are pin 4 and pin 5 looking at the front I have use NC contacts. So this is now solved thanks to all for the feedback.
  1. Live tool socket mis aligned
    By fmlfred in forum Daewoo/Doosan
    Last Post: 10-23-2017, 02:03 PM
  2. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  3. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  4. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
