586,082 active members*
3,769 visitors online*
Results 1 to 16 of 16
    Mar 2006
    81
    Question Haas OL-1 Live Tooling
    Good morning, all.
    The company I work purchased an additional Haas OL-1 Lathe with the optional Live Tooling, and they want to see it in action.
    I'm trying to set it up to do some holes on the workpiece (on the C Axis), but the example on Pg 167 of the manual... I don't quite understand it.
    The Example shows the following:
    O00800
    N1 T101 (Radial 1/4-20 Tap)
    G99 (Necessary for this cycle)
    G00 Z0.5
    X2.5
    Z-0.7
    S500 (rpm should look like this, cw direction)**
    M19PXX (Orient spindle at desired location)
    M14 (lock spindle up)
    G195 X1.7 F0.05 (thread down to X1.7)
    G28 U0
    G28 W0
    M135 (Stop live tooling spindle)
    M15 (unlock spindle brake)
    M30
    I can see this bit of code doing one hole... but I don't understand how this makes more than one hole (though it probably has something to do with that Reset Axis G28's hanging out right before the M135).
    From what I can understand from this code, it's doing the following:
    O00800
    N1 T101 (picking tool, first line number)
    G99 (setting the spin to RPM mode)
    G00 Z0.5 (rapid horizontal)
    X2.5 (rapid vertical)
    Z-0.7 (rapid horizontal -left- from previous Z point)
    S500 (setting the rotational spin speed)
    M19PXX (M19 rotates spindle, PXX, where XX is a degree, orients the thing to a particular degree, so P90 rotates 1/4 around, P270 rotates 3/4 around, etc.)
    M14 (Prevents the spindle from turning, I'm guessing while the drilling on the contour happens)
    G195 X1.7 F0.05 (Live Tool drills into OD of 1.7 at a rate of 0.05... and back?)
    G28 U0 (Resets incremental axis of X?)
    G28 W0 (No idea, probably resets incremental axis of Z? The manual's parameters for this example only show the variables F R U X and Z)
    M135 (turns drill off... although I didn't see a previous code that turned it on...)
    M15 (unlocks the spindle brake, so I guess the thing can spin again)
    M30 (Program ends... but I didn't see it loop back and do another hole...)
    I was told by someone here that the OL-1 is one of a few lathes that has live tooling available, and the online help on drilling will be difficult since most of what I will find is for Milling machines.
    I just want to have a canned cycle (if possible.. is there one?) that'll drill a number of holes I specify in the OD of a workpiece, by rotating, then drilling, then rotating, etc. I didn't think it would be difficult, but the example is tripping me up.
    Am I forgetting something?
    I'm sorry if anything above got posted before. I used the search function and couldn't find anything 'cept one thread that didn't really shed any more light on the subject.
    Jul 2005
    12177
    It is not any consolation I suppose but that example makes no sense to me either. I am not near manuals at present but I will pull out what I have later.
    May 2007
    14
    sl-10 live tooling
    O00800
    The G28 U0 is machine home in x and G28W0 is machine home in Z
    After your G195 cycle (in which you also need a reference point return (R) you need to unclamp the spindle with M15. Then rotate to your next position and clamp spindle again. then you run another G195 cycle.
    Stefan 2108
    Mar 2006
    81
    Ahhh, I think I see.
    Another thing that was tripping me up is that they put two asterisks in the example after S500 (I guess to add emphasis, or for some footnote somewhere... which I didn't find), as well as adding a note on top of the page to the parameters of G195:
    G195 Live Tool Radial Tapping (Diameter) Group 00)
    F Feed Rate in inches(mm) per minute
    R Position of the R plane (this part here I didn't understand)
    *U X-Axis incremental distance
    *X X-axis motion command
    *Z Position of bottom of hole (or this part, I thought Z was a horizontal movement placement)
    Afterwards it has the same thing but for G196 (Reverse Live Tool VECTOR Tapping (Diameter) (Group 00))
    Then it has a little note (but no asterisk for it) saying "These G Codes perform live tooling radial or vector tapping on a lathe; they do not permit an "R" plane.
    This trips me up further since the latest reply mentions this "Reference Point Return (R)". So is the manual wrong and they do need an R plane? Or do they mean that only the asterisked Parameters do not need one?
    Anyway, at least I now know that if I want four holes, I'm gonna have to write four snippits of code with the same info, and eight if I need 8, and 16 if I need 16... I was hoping that, like a canned cycle, one could program it to perform a DOWHILE or something... which I suppose can be done with a little programming knowhow... *sigh*
    EDIT (Update): Ran the example using MDI... with some changes to the X's and the Z's.
    The spindle does lock, but after it locks, it doesn't want to rotate the 90 degrees that I asked it for. It looks like it wants to move but the brake is stopping it.
    I wrote the following (in MDI, sans the % sign):
    G99
    T101
    G00 Z0.5
    X1.000
    S500
    M19 P90
    M14
    G195 X0.75 F0.05
    M15
    S500
    M19 P180
    M14
    G195 X0.75 F0.05
    G28 U0
    G28 W0
    M15
    M30
    I'm pretending that my T101 is my live tooling tool, but in reality it's not, it's just another tool, but for the purposes of testing (and the fact that they've not purchased drillbits for the livespindle) it works.
    Okay, the spindle does lock up, but won't turn the 90 degrees I want when I call for the M19. It looks like it wants to start up, but the brake clamping stops it. This happens again when I call for it to rotate 180. The G195 does happen twice like I ask it too.
    Maybe we don't have a spindle/chuck capable of it? I don't think my superiors would do that... Weird.
    May 2007
    14
    Talking sl live tooling
    you need to add a dwell G4 P(value) in order to give the brake time to open before rotation
    Mar 2006
    81
    Cool
    Thanks for the tip, that helped out a bit. I'm very grateful for all your responses, guys.
    I got the M19 to 'somewhat' do what I wanted, but as it turns out, it wasn't necessary, because...
    ...I was on the phone with Haas for a while yesterday afternoon, and they have a feature on the OL-1 whereby the C Axis works on it if it's engaged. After jumping through a few hoops or so, it turns out that there is an
    M154
    that turns the spindle into a C-Axis drive, allowing me to command the rotational axis using C coordinates, such as
    C45.
    for 45 degrees from the origin.
    This feature is cleverly hidden so that there's nearly no clues to its usage in the manual in the example for the Radial Live Tooling example (instead, that example uses the M19 PXX code, which... seems to be a pain to use given the circumstances).
    The C-Axis is an optional feature on the Haas, and thus, there seems to be nothing even mentioning C coordinates at all in the (generic) manual, from what the guy on the phone said (he said it in nicer terms though). It's one of those 'hidden' things that you'd only know about by actually calling Haas and asking.
    The only clue I had at first was the G/M-Code sheet that's laminated and placed inside the drawer for the OL-1. That's the only thing that mentions "C Axis Engage". The book has one tiny blurb (found after spotting that) at the very end of the "G Codes & M Codes" section, that says:
    M154 C-Axis Engage/M155 C-Axis Disengage (optional)
    This M Code is used to engage or disengage the optional C-Axis motor
    all the way at the very end in pg175.
    That's when I decided to call 'em. This was late yesterday though.
    I guess if the C-Axis wasn't there, one would use the M19...?
    ANYway, here's the new code that does what I want:
    G99; (RPM Mode)
    T101; (Tool Change)
    G00 Z0.5; (Rapid)
    X1.0; (Rapid);
    M154; (C Axis engage)
    C45.; (rotate 45 degrees. Note the period)
    M14; (lock spindle)
    G04 P4.; (4-second dwell as recommended. Spindle appears to vibrate a bit from the braking for about...oh... 2 seconds or so)
    G195 X0.75 F0.01; (drilling cycle)
    M15; (unlock spindle)
    G04 P1.; (1-second dwell as recommended)
    ; (repeat previous seven blocks as below, changing the degree)
    C90.; (rotate 90 degrees this time)
    M14; (lock spindle)
    G04 P4.; (4-second dwell)
    (repeat the seven blocks ad nauseam, the only change is the degree)
    M155; (C-Axis disengage)
    G28 U0; (Home X)
    G28 W0; (Home Z)
    M30; (Program End & Rewind)
    One thing of note is, I'm not all that fond of the C-Axis's rotational speed as it goes from one degree to the other. It's very very fast! :O Adding S values to the M codes doesn't change anything, it still servoes to 45, 90, etc. degrees very very fast! I've got to look for a parameter or a setting in the machine to slow it down. As an experiment, I decided to go all the way to 270 degrees from zero, and the thing gave me a nasty sound when it reached its destination.
    I didn't like that at all. I'd like to slow down the spindle C-Axis.
    I also don't like that you have to keep re-enabling the C-Axis. Every time you do that, it resets back to C Origin before turning to the angle needed (and at 'ludicrous speed', too). Tried running without the M154 (just putting it on top) and as soon as the drilling was done and I needed to turn again it gave me a "C axis not engaged" alarm. :\
    May 2007
    14
    Unhappy c-axis
    we´ve also been able to decipher our manual with direct help from HAAS.
    It seems that when using a flatening cycle the slowest spindle rpm is 3. this can only be achieved by specifying the S value directly on the flat cycle block otherwise it will default value of 6.For example G77J0.625I0R0.25K2S3.
    greetings from germany
    Mar 2006
    81
    Unhappy
    That was a good idea to try out.
    Unfortunately, it did not work for me, it still turns at a speed too fast for its own good.
    If I wanted 8 holes on this, by the time you get to hole 5 it starts making that sound. I suppose I could tell it to rotate in the other direction, but that's not a 'true' solution. :\
    Sounds like if I didn't hit the clutch while changing gears. I'd like to avoid that noise, as it sounds like stuff could be getting messed up in that spindle.
    Nov 2005
    219
    I belive the G99 is Feed per revolution. G98 is Feed per inch.
    I think there is alot of simularities between Haas and Fanuc.
    May 2007
    14
    Question sl live tooling
    what if you add a g01 & a F command to your c (angle) command
    G01 C90. F.05
    Mar 2006
    81
    Ooh, interesting thought.
    I'll try out using a G01 sometime later.
    PS- Yeah I wrote the wrong description. Sorry 'bout that. ^^;;
    Manual calls for G99 though.
    Mar 2006
    81
    Update:
    Adding an F to the G01 C the control spits out the error "Spindle not turning".
    It seems you cannot make a C movement without locking out/resetting the X/Z movement/viceversa. It's very weird.
    Basically, if I make a movement in the X/Z axis, I have to reset the C axis. Or at least, it seems that way.
    EDIT- Sorry, I didn't realize I was the last post. I should've used "Edit", not "Reply". X_x Apologies.
    May 2006
    265
    I dont know how haas builds their machines, but other machines have parametersettings for max c-axis speed and how long time to dwell when connecting brakes, so there arent any need to program stuff like that.. If c-axis speed should be to high, the torque limiter on the spindel disconnects. If the machine makes ugly noise, I guess there is something wrong with it.
    Mar 2006
    81
    Yeah I figured it's a setting or a parameter, but I've been looking at all of them and I don't see which one I'd have to edit.
    There are probably some options on the parameters and/or settings list. I'll find out what I can. :\
    May 2006
    265
    You should get the parameter manual
    Mar 2006
    81
    Yeah I'm holding it in front of me. It's at the back of the operation manual, heh. However, it's riddled with abbreviated terms that I don't quite get, such as "LEAD COM 10E9" and "DSBL LS ZTST", and there are lots of duplicates for parts such as X, Y, Z, A, B, C T, Sp, Tt, Ss, etc.
    The stuff that 'sounds' like what I want is "Sp MAX CURRRENT" and "Spindle stop freq" and "Sp Acceleration" (which is set to 4000000, by the way).
    Also, I found another tiny blurb on pg 44 about the C-Axis. It's given me a little hope because it shows how to use Incremental C movements with an "H" variable. Here's what it says:
    Operation
    M154 c-Axis engage
    M155 c-Axis disengage
    Seting 101 Diameter used to calculate the feed rate
    The lathe will automatically disengage the sindle brake when the c-Axis is commanded to move and to re-engage it afterwards (if it has previously been engaged.)
    c-Axis incremental moves are possible using the "H" address code as shown in the following example:
    G0 C90. ; (C axis moves to 90. deg.)
    H-10.; (C axis moves to 80. deg.)
    Sample Programs
    (Example #1)
    M154
    G00 G98 (feed/min) X2.0 Z0
    C90
    G01 Z-0.1 F6.0
    X1.0
    C180. F10.0
    X2.0
    G00 Z0.5
    M155
    (Example #2)
    (assume pilot hole is already drilled.)
    N1 T303 (small end mill)
    N2 M19 (Orient spindle)
    N3 G00 Z0.5
    N4 G00 X1.
    N5 M133 P1500
    N6 G98 G01 F10. Z-0.25 (plunge into pre-drilled hole)
    N7 G05 R90. F40 (Make slot)
    N8 G01 F10. Z0.5 (Retract)
    N9 M135
    N10 G99 G28 U0 W0
    Example 1 does a cut with a drill that's perpendicular to the diameter of the workpiece inwards, then the spindle rotates as the drill stays in a spot. Then after the piece has rotated in 180 degrees, the drill comes out, leaving a slot on the side of the piece that resembles an Omega symbol. They didn't label the line numbers, but I understand it.
    Example 2 inserts a drill into a previously drilled hole on the side of the workpiece, then rotates the spindle cutting an arc in the side of the workpiece, finally having the drill come out at the end.
    These are all tools that are perpendicular to the OD, though... They don't have a (good) example of a tool that is parallel to the OD and perpedicular to the Z axis, doing drill holes using C.
    I'm going to try using the H code while I have someone look into how to slow down that acc-wait, the example uses G98... both of them. The previous code I put up was using G99 because the example asked me to put it... but it wasn't using the C Axis, it was using those M19 codes.
    Perhaps if I switch to G98 instead of G99 and put in a feedrate similar to the one in example 1's 6th line (the "C180. F10.0" line), I can achieve what I need.
    Afterwards, I'd have to get Macro programming working in order to repeat the process, because it seems the radial/vector drilling code isn't a Canned Cycle (though it really oughtta be).
    I'll return with the results later in the week.
    EDIT (again):
    I got it to work, somewhat, though I haven't machined a part yet. Here's the code. Got it from ideas proposed by the responses above, as well as deciphering the manual:
    T101; (pick tool 1)
    M154; (c axis engaged)
    G98; (feed per minute mode)
    G00 X1.0; (move tool1 to 1" diameter rapidly)
    M133; (turn live tool on)
    G01 C90. F500.; (rotate spindle 90 degrees at 500 RPM)
    G04 P1.; (dwell for a second while the spindle stabilizes)
    G01 X0.75 F2.; (drill)
    G00 X1.0; (retract)
    ;(from now, repeat only using "H" instead of "C" for incremental C axis motions)
    G01 H90. F500.; (Incremental rotating 90 degrees from previous C degree. Spindle now at 180 degrees)
    G04 P1.; (dwell for a second)
    G00 X1.0; (retract)
    G01 C0. F500.; (return to Zero)
    M155; (c axis disengage)
    M135; (turn live tooling off)
    M30; (program end&rewind)
    This code works in that it does rotate the spindle, and does it at the rate I specify, at the degrees I specify, without returning to Zero. I guess the problem before was that I was using just C instead of H, and quite possibly the other problem was the period missing from the Feeds and the Degrees? Anyway, this seems to work. Also, it seems calling an M154 automatically locks the spindle, so there's no need to call for a lock spindle G-code (I guess?) and unlocks it after the C axis is disengaged.
    I'll try to cut an actual piece sometime, but at least the motions are now what I want.
    Another edit: You can put an M14 before the M154 and it'll lock and rotate with no issues.
  1. tuning and live tooling
    By fjd in forum Uncategorised CAM Discussion
    Last Post: 07-11-2010, 02:28 AM
  2. Need help with live tooling on cnc vtl
    By YV600 in forum G-Code Programing
    Last Post: 07-02-2007, 03:29 AM
  3. TW-10 live tooling question
    By davisboys in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2007, 01:48 AM
  4. haas live tooling
    By tgooding in forum Haas Mills
    Last Post: 12-07-2006, 02:58 AM
  5. Takisawa Live Tooling
    By TURNING MAD in forum CNC Tooling
    Last Post: 11-29-2006, 05:26 PM
