586,779 active members*
9,561 visitors online*
    Mar 2020
    Question MAHO 1000C -84
    Hi, I have serious problem with our machine. Numbers on the screen keep rolling on X axle while machine stays still. there is no dirt or oil in measureheads.Cables and Machine parametres are ok. Screen shows error X02,Y02. Really appreciate if i find some help here... sorry my bad english.
    - Maho 1000c , year -84
    - Philips 432
    Apr 2015
    170
    Re: MAHO 1000C -84
    I am not familiar with that machine but if the encoder is on the servo motor which they often are the motor could be turning without moving the table. Check for a broken belt or a broken or slipping coupling. Dave
    Oct 2018
    11
    Re: MAHO 1000C -84
    Hi Mike
    Both alarms one from the measuring systems, as there are two axes in error check the power supplies.
    Best regards
    Jun 2007
    3891
    Re: MAHO 1000C -84
    Both those axes go to the same measuring board as well, so it could be the board is bad.
    I had something like that, but it was when the machine would not come out of error (bad spindle drive) and the axes WERE moving. Just very slowly. Basically, they weren't being controlled, and some tiny voltage was causing them to move around (like 0.01mm/min). The scales read the table movement directly of course, so the movement showed on the screen, even though it didn't look like the table was moving. When the machine was forced into being "on", the motion stopped.
