586,100 active members*
2,716 visitors online*
    Jul 2013
    608
    Cutting Alum. stock
    Hello guys,
    I am looking to be able to cut alum plates or stock to use on my CNC machine. I found the thread from 2005 where some of the recommendations where to use a jigsaw or table saw (yikes after reading of the dangers of kick back) I have also hear people use a bandsaw? I want something that will give me a margin of safety. I see they make some horizontal bandsaws that are pricey and large.
    I want to cut down the stock or scratch to fit in a the vise or "fixture" plate. Straight edges would be nice, but I don't think they are critical.
    I want considering something like this, knowing that I would have to get a metal blade.
    I am considering this model seems to be the best bang for the buck providing two speeds and having a 3.5 A motor. It also has a guide rail to held with straight edges.
    https://wenproducts.com/collections/...ith-stand-3962
    Any thoughts or advice would be great.
    Quote Originally Posted by FoxCNC1 View Post
    Hello guys,
    We use a chopsaw with a metal blade on it. Works great just go slow and keep your teeth on the blade clear and clean
    Jan 2016
    120
    Re: Cutting Alum. stock
    I've been in the same boat recently. I think two of the big factors are how much space you have for equipment as well as the size and thickness of plate you want to cut. If you're not cutting anything too wide or thick I think a chopsaw is the best idea. I am personally going to save up and get a Dake Work A Matic band saw. I believe most metal blades for bandsaws recommend a max speed of around 350 FPM, so watch out for bandsaws that cut too fast.
    Nov 2007
    479
    You can always have your metal supplier quote your stock with saw cutting, typically it doesn't cost much for an value added service like that.
  1. Cutting alum on a water jet- What machine to buy
    By Trell in forum Waterjet General Topics
    Last Post: 05-31-2017, 04:27 PM
  2. CNC cutting alum. bracket (2d). - need some feeback please.
    By FoxCNC1 in forum Material Machining Solutions
    Last Post: 05-24-2017, 11:05 PM
  3. dry cutting 6061 t6 alum.
    By steve cline in forum CNC Tooling
    Last Post: 12-27-2012, 09:14 PM
  4. shop air cutting alum
    By Edwardo in forum Hypertherm Plasma
    Last Post: 01-13-2011, 08:33 PM
  5. bending a spiral out of alum square stock
    By Rich05 in forum Bending, Forging, Extrusion...
    Last Post: 09-08-2010, 03:24 AM
