586,111 active members*
3,744 visitors online*
    Dec 2011
    5
    Question M19 in sinumerik 820 m ga3
    hi to all
    in my cnc milling machin (sinumerik 820 m ga3) 3 axis, I want to orient the spindle for several angles (from 0 to 360 - @410 k0 k4020) , so I use M19 code for this , I can change the angle for M19 in SD 4020 , after entering the M19, I can turn the spindle by hand and I dont want it .
    I want to use spindle without rotating for special cutting like broaching in material . I changed the ( Servo enable delay) MD 447* to increase the time for stay in M19 mode . but it doesnt work and the spindle turn by hand easily . would any body help me to do it ? is it relate to gain spindle motor or another things?
    it is important that my MILLING machine works very good and I use M19 for tool change . but I want to broach a workpeace by not rotate the spindle .
    thanks and the best regards
    Dec 2011
    5
    Question Re: M19 in sinumerik 820 m ga3
    hi to all
  1. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  2. Sinumerik 3M
    By NC-Technik in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 12-29-2011, 03:13 AM
  3. sinumerik
    By karci in forum SIEMENS -> GENERAL
    Last Post: 12-13-2011, 04:16 AM
  4. sinumerik 3m
    By djordjrvic in forum SIEMENS -> GENERAL
    Last Post: 04-07-2010, 02:08 PM
  5. can't run sinumerik
    By dato in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-24-2007, 02:48 PM
