586,071 active members*
4,374 visitors online*
IndustryArena Forum > CAM Software > Hypermill > Easy indexing with gun drills on 5 axis FPT Dino?
    Jun 2015
    76
    Hi all,
    Is there a easy way for indexing in the software?
    We do a lot of parts with deep holes and long tools, and I have to make two frames, a pattern and a sketch with two lines to control the tool in my program every time I move to a new frame.
    The problem is the movement of our spindle head, if I don’t do this rather bumpy programming, the machine just moves reference point in Z and turn the head at position. Using long tools, the machine will crash and destroy itself!
    The machine can move by tool tip with a cycle, I am told that powermill made a post processor that does this.
    And I was told that the local reseller can’t help with this...
    I will take some screen shots at work, some times pictures shows what can’t be written...
    I hope someone understand what I’m writing, I’m from Denmark and my English is not the best:-)
    Cheers, Daniel
    Jun 2015
    76
    Edit: I was told that the reseller can’t help with the Post edit. I’m the new programmer using Hypermill, we are two programming 5 axis work in Hypermill, and I only have one to ask for help. I use forums to get new input on things that I feel can be made easier??
  1. Replies: 2
    Last Post: 01-06-2013, 03:08 AM
  2. Dino might!
    By cncadmin in forum EnRoute
    Last Post: 10-12-2011, 08:30 AM
  3. X Axis Offsets for Drills on SL20
    By rrbmachining in forum Haas Lathes
    Last Post: 10-02-2010, 07:54 AM
  4. indexing 4th axis
    By 69ss396 in forum Haas Mills
    Last Post: 12-03-2008, 10:06 PM
