586,069 active members*
3,634 visitors online*
    Vacuum Forming Shrinkage and Control
    Hi Everyone,
    We recently go into Vacuum forming process. We mostly form 0.125'' HDPE sheets to build fenders and other panels. I know from online research that HDPE has high shrinkage rate and needs to be controlled carefully.
    So once the molds are pulled, how long should one cool them? I wanted to know the timings of the cooling cycle. Also based on the few trial parts pulled, which were cooled to room temperature before taking off the machine.
    I have observed that the parts warp a lot. Should the parts after being pulled and cooled, still be mounted on a fixture to control warp and further shrinkage? I am having a lot trouble dealing with the shrinkage and how to control it.
    And advise, manuals or documents on this would be truly appreciated.
    Thank you.
    Aug 2022
    Re: Vacuum Forming Shrinkage and Control
    Jai,
    Did you ever get any help with the shrinkage and warping issue? I am having the same problem trying to form table tops.
    Oct 2022
    Hi Jai
    Please provide a photo of your machinery and ill try to help as much as i can.
  1. Vacuum forming PS 2 mm
    By Vacuum_forming_machine in forum Vacuum forming, Thermoforming etc
    Last Post: 10-13-2019, 09:33 AM
  2. I need help with vacuum forming
    By Jessepc in forum Vacuum forming, Thermoforming etc
    Last Post: 02-05-2018, 06:49 AM
  3. A/C compressor for vacuum forming
    By Orvillefpike in forum Vacuum forming, Thermoforming etc
    Last Post: 02-14-2010, 12:51 AM
  4. Vacuum Forming with PVC
    By kaseencook in forum Vacuum forming, Thermoforming etc
    Last Post: 04-25-2009, 11:53 PM
  5. VAcuum Forming
    By rhundl in forum Employment Opportunity
    Last Post: 06-28-2008, 04:28 AM
