586,075 active members*
3,654 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > CNC goes outside limits after tool change
    May 2020
    6
    Hello,
    Using Mk2/4 with tool change.
    After some tool change (but not always), the machine moves into the wrong direction and stops because of the X or Y limits are violated.
    When "restarting the program" from the tool change line, the machine systematically do the same error. This is not a random hardware or communication error.
    If I remove all the code from the start of the file to the tool change, manually set/measure the tool, and then start the program from the beginning, it works.
    Looking at the trajectory in the software (in attachments), the computer is "aware" of this erroneous moving so it deliberately go into a wrong direction.
    I'm starting/stopping the inverter manually so I activated all the pauses available.
    I tried to set something other than the default 0/0 in the "Tool sensor" / "Tool sensor Fixed / "move" boxes. With X50/Y50 :
    - Move above tool sensor OK
    - Measure tool OK
    - Go to 50/50 (relative from tool sensor ?) OK
    - Ask for program restart (because of the PAUSE option checked), I guess, not sure
    - Go to working area FAILS, the machine move to a negative X and/or Y coordinates
    Any ideas?
    May 2020
    6
    Re: CNC goes outside limits after tool change
    up... no ideas? Official support looks to be down...
    Mar 2017
    1312
    Why do you think our support is down?
  1. Replies: 6
    Last Post: 05-10-2016, 12:30 AM
  2. FAGOR 8040 MC Z-Axis overrun software limits @ tool change
    By caecae_eng in forum Fagor Automation
    Last Post: 01-19-2016, 04:05 AM
  3. How to Change B-Axis Rotation Limits?
    By frist in forum SIEMENS -> GENERAL
    Last Post: 09-11-2013, 03:01 AM
  4. Tool offset limits
    By Oti in forum Okuma
    Last Post: 05-15-2010, 05:07 PM
  5. Tool Axis limits
    By kojack in forum Mastercam
    Last Post: 06-12-2009, 08:03 PM
