586,533 active members*
2,847 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > No negative z-numbers on wireless MPG
Results 1 to 6 of 6
    Aug 2011
    999
    I am using the wireless handwheel as supplied from Planet-CNC. Works well but have not used it extensively.
    Today I was running a tool path that starts with a positive z-value and ends up slightly negative. But noticed when the tool ends up below zero, the display stays positive.
    In that case, the screen display jumps from +2.10mm to -0.99mm (which is correct and what the bit is doing) and the MPG display jumps from +2.1mm to +0.99mm.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Nov 2015
    260
    Re: No negative z-numbers on wireless MPG
    Yes, the same here.
    Another error is that 1/100 steps are only displayed from 1mm.
    Mar 2017
    1316
    This is just display issue. I guess I overoptimized text generator algorithm and come cases are apparently not covered. Will fix this.
    Mar 2017
    1316
    I fixed missing minus character.
    I don't understand what is "1/100 steps" error.
    Nov 2015
    260
    It's been dealt with. I can no longer reproduce the error. Maybe it was just a condition error
    Jun 2017
    143
    The UI also sometimes displays -0.000 which looks odd.
  1. Anyone able to decipher Sanyo Denki 'type' numbers (model numbers)?
    By MrBinNZ in forum Stepper Motors / Drives
    Last Post: 06-24-2019, 09:56 AM
  2. Drawing Numbers and Part Numbers
    By petesurrey in forum Uncategorised CAD Discussion
    Last Post: 08-20-2013, 10:12 AM
  3. Negative tool numbers
    By declanhalpin in forum MadCAM
    Last Post: 02-14-2013, 07:56 PM
  4. How to set a negative value in THC Min (Mach3)
    By Beefy in forum Waterjet General Topics
    Last Post: 02-16-2011, 10:54 PM
  5. Negative Molds
    By schllac in forum Moldmaking
    Last Post: 12-04-2010, 05:57 AM
