586,113 active members*
3,485 visitors online*
    Jul 2016
    9
    AIR PRESSURE SENSOR
    we have some troubleshooting with our vertical center VF3 SS YT.
    we need help with the reference of the air pressure sensor, and where we can buy it.
    thank you for help.
    Dec 2013
    5717
    Re: AIR PRESSURE SENSOR
    Jim Dawson
    Sandy, Oregon, USA
    24221
    Looks like a standard device, have you checked out any local pneumatic vendors?
    Al.
    Albert E.
    Countryguy1225 Guest
    If there is any PN, model, or imprinted info on it... pass along. As AtM notes.. they are pretty standard devices. Haas Parts is usually ok on these type of small items though...
    Hi JD! Nice to see the title on your IF here.
  1. synrad evolution RF 3000 power suply water pressure sensor broken?
    By dominikp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2015, 01:33 AM
  2. ATC Pressure Sensor
    By LRF in forum Tormach Personal CNC Mill
    Last Post: 06-18-2014, 02:35 AM
  3. Stepper motor as pressure sensor
    By Akros in forum CNC Machine Related Electronics
    Last Post: 02-13-2010, 12:09 AM
  4. Axis movement speed adjusted by pressure sensor
    By Viesturs in forum Controller & Computer Solutions
    Last Post: 05-20-2009, 12:44 PM
  5. DIY pressure sensor ? - Touch Off Plate ?
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 06-22-2007, 10:56 PM
