586,077 active members*
3,649 visitors online*
    May 2020
    Dyna Myte 2400 and Mach3
    Hi folks,
    I have bought a Dyna Myte 2400 and now I want to connect it to mach3. Unfortunately, I have no idea how to configure mach3 to get it working with the dyna myte.
    I have connected my PC via plain 25pin parallel port to the milling machine. Is this correct? How do I need to configure the I/O in mach3 to get the machine working.
    I have also read about refitting the Dyna Myte to work with mach3. Is this absolutely required? Or should it work with stock electronics also?
    Regards,
    Tom
    Re: Dyna Myte 2400 and Mach3
    I have no direct experience with the DM 2400, but the control is quite similar to the DM 3000H lathe that I have. That 25 pin connector that you're connecting to is most likely an RS-232 serial port for sending programs to the SKIP controller.
    Sorry, you won't be able to just connect a PC with Mach3 and go like you're trying.
    Dave
    Aug 2020
    13
    My DM2400 was retrofit (by the guy I bought it from) with a Centroid Acorn controller and a Gecko stepper driver. The Acorn talks to the PC via Ethernet. There's a 25 pin cable between the Acorn and the Gecko. Works very well. No issues.
  1. Dyna Myte 2400
    By Bertake in forum Uncategorised MetalWorking Machines
    Last Post: 04-14-2013, 02:39 PM
  2. help dyna myte 2400
    By galluko in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2013, 09:44 PM
  3. DYNA MYTE 2400
    By helfriwj in forum Benchtop Machines
    Last Post: 04-02-2008, 04:45 AM
  4. Need Dyna Myte 2400 controler
    Last Post: 02-13-2008, 09:34 AM
