586,060 active members*
4,154 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > PC Turn 120 Floppy Disk Images?
    Jun 2017
    22
    Does anyone have the floppy disks for a PC Turn 120? I've finally powered mine up and it's asking for a system restore disk. If you have them, would you be able to take some image backups of the floppies please?
    I suspect it might need a new hard drive so that's on order too.
    Nov 2012
    367
    Re: PC Turn 120 Floppy Disk Images?
    Hmmmm, I have one of those as a spare control, but I don't think I have any disks for it. However, I wouldn't use the drive anyhow. I'd suggest you move to RS232. Once you setup the parameters, then you can push the parameters that way. Unfortunately, the MSD is technically specific to a machine because it includes backlash. if you had an EmcoTurn 120 or Compact 6 I could help you, but the PC Turn 120 is not anything I have experience with. Sorry.
  1. Replies: 13
    Last Post: 04-11-2022, 07:43 PM
  2. Floppy disk
    By KHOATRANNGOC in forum Okuma
    Last Post: 06-13-2019, 12:28 AM
  3. Floppy disk...
    By Bluegillman in forum HURCO
    Last Post: 05-25-2018, 07:13 AM
  4. No floppy disk, only USB
    By davedaneels in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-13-2008, 11:37 AM
