586,119 active members*
3,631 visitors online*
    Apr 2018
    9
    Extended Z Axis
    I need to use the area above the CS Position for clearance, Do I need to use the Set Ho Command? It has the Extended Z Axis.
    Oct 2008
    1632
    Re: Extended Z Axis
    You could set the second home then use G28, or just use G28 then a G91 Z3.0
    That would go to CS Z0 then go up another 3" right?
    Apr 2018
    9
    Re: Extended Z Axis
    Ill give that a try ..Thanks
  1. G0704 extended Y axis??
    By Jim27 in forum Benchtop Machines
    Last Post: 12-26-2014, 03:11 AM
  2. Extended Y axis
    By Twingy in forum Taig Mills / Lathes
    Last Post: 09-23-2011, 10:55 PM
  3. Extended X-Axis X2 Done!
    By Tallen in forum Benchtop Machines
    Last Post: 09-25-2009, 08:30 AM
  4. X2 extended X and Y axis
    By eartaker in forum Benchtop Machines
    Last Post: 09-04-2009, 09:14 AM
  5. Building a CNC mill based on X1 parts / extended axis kits
    By Qwerty256 in forum Benchtop Machines
    Last Post: 04-29-2007, 12:05 AM
