586,271 active members*
3,918 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Using FTP to continuously use the same program name
    Mar 2020
    13
    Hello.
    We purchased Robordrill CNC machine with 30i controller.
    We're use FTP connection and can read files normally. We're used to process gcode on the pc and then just process the file on a machine. We do not store any programs on the machine and just use bogus file names. Problem is that, when we read the program from the FTP, it saves it's name in the memory and we cant use the same file again. It usually takes us few "downloads" before the program is good and without errors so we now need to change it with every run. Is there a way to avoid this? We'd like to just use same file name and just override whatever is in memory. Is it possible?
    Thanks in advance!
    Re: Using FTP to continuously use the same program name
    Try setting (REP) Parameter 3201 bit #2 xxxxx1xx (where x is don't change).
    REP Action in response to an attempt to register a program whose number is
    the same as that of an existing program
    0 : An alarm is generated.
    1 : The existing program is deleted, then the new program is registered.
    Note that if the existing program is protected from being edited, it is
    not deleted, and an alarm is generated.
    Mar 2020
    13
    Thanks. That's great news. Will try it and report.
    Mar 2020
    13
    Works like a charm. Thanks @drdos
  1. 4th axis is not rotating continuously
    By pcreek in forum MadCAM
    Last Post: 04-01-2019, 01:27 AM
  2. Continuously lost Z
    By ToolChatter in forum Bridgeport / Hardinge Mills
    Last Post: 06-24-2015, 11:56 PM
  3. Repeat subprogram continuously.
    By sandrewb in forum Fanuc
    Last Post: 04-09-2015, 01:46 PM
  4. How long can you run a Dremel continuously?
    By Fozzie55 in forum WoodWorking Topics
    Last Post: 07-11-2011, 05:48 PM
  5. Replies: 2
    Last Post: 10-21-2010, 03:24 PM
