586,426 active members*
3,264 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > My AC servo minas A6 is shaking too much
Results 1 to 7 of 7
    May 2020
    I am using a AC servo minas A6 (MSMF082L1U2) with drive MCDLT35SF. When testing with dynamic load, servo running unstable (too much vibration and oscillation). Everything is running usual when i test without load or load under 100 grams.
    Anyone can help me with this (reasons and how to fix it). Thanks.
    Dec 2013
    5717
    Re: My AC servo minas A6 is shaking too much
    Try increasing the D value in the PID settings
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by minhduc341 View Post
    Go through your manual
    Set the parameters for machine rigidity / stiffness then auto Tune this will get you close then you can adjust 1st Gain Loop 2Gain Loop Etc
    Your problem right now is your Gains are set to high
    Mactec54
    15362
    And where would he find a D value in his servo drives
    Mactec54
    Dec 2013
    5717
    Is there no way to adjust the PID in that drive?
    Jim Dawson
    Sandy, Oregon, USA
    15362
    You should understand the servo drive that the question was being asked about most modern servo drives are setup completely different I have not looked but I don't think you will fined the word PID in the manual
    Mactec54
    May 2020
    Thank you, that help me a lot
