586,036 active members*
3,497 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Has anyone built a CNC machine with a feed system for the y axis?
    Nov 2008
    5
    Not sure where to ask this question but the CarveWright system uses a rolling feed system for the Y axis and I was wondering if anyone has made a larger sturdier version themselves? It would be nice to have a machine that took less floor space when not in use. Anyone have advice on things that could be used to make such a system if not.
    James.
    Re: Has anyone built a CNC machine with a feed system for the y axis?
    This is the closest thing I've seen.
    Start reading at this post.
    https://www.cnczone.com/forums/cnc-w...ml#post1209536
    Oct 2009
    483
    This is maybe not quite what you had asked for, but here is another idea for a space saving router.
    Attachment 443028
    https://youtu.be/xIGre_E2_og
    Nov 2008
    5
    Thanks both, I might try the 3D printed one it could be handy!
  1. 5axis machine is not operating on Constant given Feed while using A-axis and C-Axis
    By solowalker41 in forum Drilling- and Milling Machines
    Last Post: 12-09-2017, 07:45 AM
  2. First pass of X2 mini mill power feed I built
    By RCWorks.com in forum Videos
    Last Post: 07-30-2017, 03:12 PM
  3. Automated feeding system to feed the parts into CNC machine
    By maheshvyavahare in forum For Sale Only
    Last Post: 09-22-2015, 06:05 PM
  4. Home built 5 axis machine
    By csmoak25 in forum DIY CNC Router Table Machines
    Last Post: 02-15-2011, 03:56 AM
  5. 4-5 axis control recomendations for home built horizontal machine
    By Kmed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2005, 11:04 PM
