586,112 active members*
2,956 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Servo Amp /Motor settings Help
Results 1 to 6 of 6
    Oct 2017
    15
    I have an alpha motor part number a22/2000 running on servo amp part number A06B-6079-H208 and both axis work fine I can run them forwards and backwards.
    When I connect a A06B-6079-H106 amplifier with the same parameters and motor and the motor does this (see video) any ideas?
    https://photos.app.goo.gl/VF8LVZhKt6ZGXqUX8
    At this point I am not even trying to run the motor it is in holding torque waiting for a command. I have set servo parameters to be correct for that motor (20 in the servo parameter page).
    Can anyone help?
    Sep 2007
    7
    Re: Fanuc Servo Amp /Motor settings Help
    From the Fanuc manual the A06B-6079-H208 is specified 80/80 and the equivalent for one axis is A06B-6079-H105.
    So, inside the amplifier the firing board is diferent in electronic components that has the -H106
    Oct 2017
    15
    Quote Originally Posted by berthagua View Post
    thanks for replying - so is it not possible to get an a22/2000 to work on this A06B-6079-H106? ie it will never work?
    Dec 2015
    171
    A06B-6079-H106 amplifier works fine with a22/2000 motor & no need to change any Parameters.
    A06B-6079-H106- 9.1kw & rated output is 52.2Amp
    A06B-6079-H208- 9.5kw & rated output is 18.7Amp
    need to know that A06B-6079-H208- is dual axis drive
    A06B-6079-H106- is single axis drive.
    if you replace drive from -H208 to -H106 you have need more 1 more H106 drive or lock 1 axis by Parameters or dummy on axis board.
    Oct 2017
    15
    Quote Originally Posted by phucrobusl View Post
    hey tried to DM you but couldnt get intouch (messages exceeded quota). drop me a message @phucrobusl
    Oct 2017
    15
    lol just got this error message so cant get intouch... @phucrobusl
  1. Replies: 0
    Last Post: 02-19-2020, 08:05 AM
  2. Replies: 3
    Last Post: 02-11-2015, 06:07 AM
  3. FANUC Servo Settings
    By gbowne1 in forum Fanuc
    Last Post: 10-30-2013, 02:59 PM
  4. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
