586,076 active members*
4,037 visitors online*
    Heidenhain Scale old LF183 C
    I replaced Heidenhain Scale on gear grinding machine old scale was LF 183 C new scale model LF185C after power On the axis is not referencing ,can somebody help me
    Sep 2009
    99
    Re: Heidenhain Scale old LF183 C
    Hi Sundaraj51,
    Is the axis moving OK? LF 183C and LF 185C are distance coded scales which should be interchangeable without any issue. As per this, the machine should be able to find the reference within a 40 traverse.
    Which controller are you using? Some more information regarding the machine would be helpful
    Best regards
    JSS
  1. Heidenhain Scale LS 703 ML 920mm 216 750 13
    By AlexP in forum For Sale Only
    Last Post: 02-27-2020, 03:22 PM
  2. Replies: 1
    Last Post: 10-02-2015, 05:34 AM
  3. Blacklash with glass scale Heidenhain
    By tapinlu in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2015, 05:16 AM
  4. Need to make scale tire mold for 1/6 scale car
    By thuffner3 in forum Moldmaking
    Last Post: 04-29-2008, 06:57 AM
