586,094 active members*
3,758 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Avid CNC Slaved Proximity Sensor for Ganrty Auto Squaring
    Hoping someone here can help. Avid CNC is no help, their support sucks!
    I have a 4x4 machine using their plug and play NEMA 23 electronics. When I purchased It I only got 3 switches for homing. Now I have purchased a sensor to add to the slaved Y axis for auto squaring of the gantry, but I can't figure out how to set it up in Mach 4. When I have the switch plugged into the slaved input the light comes on when metal is touched to it, but nothing lights up on the 'Diagnostic' tab on Mach 4. Although the diagnostics tab for the ESS does show that it's getting a signal. Just don't know what I need to do to get it working.
    Thanks!
    Jan 2014
    29
    Re: Avid CNC Slaved Proximity Sensor for Ganrty Auto Squaring
    There support is very good.
    Is each switch wired to a separate input or are they combined or parallel?
    What controller are you using to wire them? Can’t remember what electronics they use.
    I have mine auto squaring in Mach4 but I have each switch on a separate input.
    Much simpler control logic to program this way.
  1. Having issues with Proximity Sensor
    By john_in_Tacoma in forum Avid CNC
    Last Post: 07-12-2019, 11:13 PM
  2. Replies: 3
    Last Post: 06-26-2018, 06:56 PM
  3. Squaring X-Y Axis - Home Sensor adjustment question
    By ifeliciano in forum Avid CNC
    Last Post: 12-09-2017, 09:44 PM
  4. Squaring a slaved Gantry machine
    By markskells in forum DIY CNC Router Table Machines
    Last Post: 08-02-2016, 07:58 PM
  5. CRP's Proximity Sensor Kit
    By rwskinner in forum Avid CNC
    Last Post: 02-12-2014, 04:07 AM
