Hi guys,
I'm doing the installation of a CamSoft system on a lathe for a friend. The hardware came with a Adlink PCI-8136 DIO board, not the CS-16600 Motion Board as mentioned in the "Wiring Notes and IO Map Summary.pdf"
"Wire the Axis Servo motor and encoder connections per Chapter 8 titled “CS-16600 Motion Board” in the “Installation Guide.PDF” file."
And it references the ICM-1900 and ICM-2900 boards, which we also don't have.
With this said, the issue at the moment is that the Installation Guide doesn't say where to put the +24VDC and 0VDC wires. I'm also skeptical as to the wiring guide that we were given, so I'll follow this up with CamSoft support as well, but I was hoping that someone knew what was going on.
Thanks!
John
