586,103 active members*
3,701 visitors online*
Thread: DIY Upgrade
    May 2020
    DIY Upgrade
    Hello All,
    I have an older TM2 and I am wanting to do some upgrades as I see them. The table itself is a 4 x 8 and doesn't owe me a cent hence the reason I would like to look into upgrading and "tightening" the operation up prior ro considering the purchase of a newer table.
    I have just installed new motors on the x and y, as I added an z axis along with a Stingray THC Lifter by Flashcut CNC. I cant remember the size of the motors but can get that information if required to help define mt setup.
    What I am now looking to do is;
    1. Add another motor on the x axis (that will be slave) so that I can improve some cutting smoothness. The cuts are fine, I just feel that I am wearing through the shaft that connects both pinions prematurely. I feel that this is due to the weight of the gantry. The cassette on there is 30mm (+/-) and all it carries is the plasma torch and the THC Lifter. I figure that thing (gantry) to be at about 160lbs (guess) so if I can lighten the load I'd like to;
    2. Rack location. For those that are familiar with this model of table the rack is on the inside. I dislike that now based on a year ago when I wasn't that conversant with CNC anything. So I would like to move those rack to the outside;
    3. Look at cost effective options to expand this table to a 5 x 10 short of buying a new one. Perhaps the better option is to do that but I am happy with everything else and there seems to be a hidden value in building it myself rather than getting someone to do it for me. I can stay with the 4 x 8 but having the flexibility of a 5 x 10 makes getting max use out of a 4 x 8 sheet not such a consumption of time in set up.
    4. I'd like to build a pendant. Again for a satisfaction thing. Currently I run all my controlling from my work station which is facing away from the table when cutting. When babysitting it, I'd like to be able to manipulate position of torch and stop as I see fit. Is this even possible?
    I know a lot for a newb, but I am somewhat familiar with my setup and not afraid to tackle a challenge especially in the name of knowing how to do it. I feel that to be a problem if I just source all these upgrades. If it comes to a problem I will never know how to fix it. Already the case at times with the software that I run.
    So any pointers, suggestions, places to look, things to consider would be greatly appreciated. Perhaps pictures of previous similar upgrades? I am going to target this upgrade for Jan 2021 as that is my assumed slow period, so I have between now and then to find parts, line up build, etc to limit downtime once I take the machine down.
    Thanks in advance folks.
    Feb 2016
    50
    Re: DIY Upgrade
    Hey how are you liking the new Flashcut verse old 401A?
    I have the TM2 as well. I wear out the pinions on the y axis quick too. I was going to do the same as you mentioned and put new racks on the outside.
    I priced new racks. Mine are getting worn. I found some that are a full solid 8' 2". But TM 49" x2 parts are priced well.
    But for my current project is a TM3. It has the already racks mounted on the outside by OEM. But need to bring it back to life. It doesn't have any electronics other then the z smart motor.
    Which Flashcut did you go for the Compact or Pro series. I got a quote for the Pro but that was costly for the cause. Could ask for the Compact.
    Also got any controls to sell. Because I'm shopin.
    Mar 2004
    413
    Re: DIY Upgrade
    Frankly, on the plasma machines I built over the years, also using Flashcut, I've had my best experiences using a wireless Logitech game controller (F710) with the buttons mapped to keyboard commands via one of the available software programs that do such. JoyToKey is the one I still use, though I know others exist now.
    Entering Jog Mode, All the speeds of Jog, Feed Hold, Start, Set0, Etc. fit onto a single game control, and it really does feel much more useful to me than a traditional pendant, where you have to SELECT which axis you want to move.... the joystick and the two front buttons are always ready to go!
    Chris L
    Feb 2016
    50
    Re: DIY Upgrade
    I just use usb wireless Logitech K400 keyboards on all my machines.
  1. Replies: 5
    Last Post: 04-15-2015, 05:10 PM
  2. V26 upgrade
    By rjmorel in forum BobCad-Cam
    Last Post: 11-25-2014, 10:38 PM
  3. DIY Upgrade
    By vwpanda in forum DIY CNC Router Table Machines
    Last Post: 02-05-2010, 07:35 PM
  4. Vmc 40 -5 upgrade
    By redman in forum Fadal
    Last Post: 11-19-2005, 02:22 AM
