586,123 active members*
3,548 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > toolpath generation algorithm for NURBS
    May 2007
    Hi there,
    I'm looking for an implementation of a toolpath algorithm
    to mill 3d convex nurbs- or even polygonal surfaces on
    a 3-axis milling machine. preferably it has a way of
    specifying the tool contour from spline or polygonal
    data as well. The output should be a set of contours
    for each tool as hpgl or gcode.
    Does anyone have a tip on where to find such
    software ?
    thanks in advance,
    Jonathan
    May 2006
    16
    Pardon me,
    Are you looking for actual programming code algorithms, or simply a cam package that does what you're asking ?
    I have some crude algorithms in Java for doing parallel lace on a triangle mesh, but thats about all.
    Certainly keen to compare notes and learn faster ways to do things, since my methods are bit brutish !
    Cheers.
    May 2007
    Hi There,
    I am looking for actual code, which is a bit smarter than
    just scanlining a heightmap and takes into account that
    it is quicker and nicer to go around a circular or cylindrical
    area in a (NURBS) patch in circular motions. It'd also be
    nice if it takes into account possible concave shapes when
    using a convex tool. But it seems there is very little public
    domain software for this. I am about to write it myself using
    a brute force voxelspace-conversion and then 'stamping out'
    the tool covering only voxels that are to be removed. this way,
    you dont _have_ to follow a scanline- or any grid-like pattern.
    any thoughts on this ?
    J
    Wink nurbs
    Hi Jbacon
    not sure if i fully understand your requirement or needs, You did not give any idea of the application or type of part you want to machine, or the machine & Control.
    When we looked into nerbs progranning back in the 1990's it was because the controls of the time were not fast enough to process the line data, and as a way of overcoming this the M/C tool guys proposed programing in Nerbs splines. But as time and controlers have moved on, this option is spoken about less and less.
    I have a Post processor that will output a Nerbs spline for machining with. contact me and we can discuss it.
  1. Algorithm?
    By CNCgr in forum OpenSource Software
    Last Post: 12-08-2009, 12:23 AM
  2. MASTERCAM 9.1 TOOLPATH GENERATION for Mach3
    By chris59 in forum Mach Software (ArtSoft software)
    Last Post: 11-18-2006, 05:58 PM
  3. Full 4 axis toolpath generation?
    By Konstantin in forum Rhino 3D
    Last Post: 11-12-2006, 07:14 PM
  4. Need FANUC NURBS info
    By RayDOsity in forum MetalWork Discussion
    Last Post: 03-31-2006, 04:20 PM
  5. Nurbs, points, polymesh, 3DS, WTH?
    By InspirationTool in forum Uncategorised CAM Discussion
    Last Post: 10-08-2005, 08:20 PM
