586,062 active members*
4,608 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Connecting SMPS in parallel?
    May 2020
    Hi
    I see that many of us here power steppers by boosting ATX PSUs to 24V/32V/etc, but is it actually safe to connect SMPSs in parallel? Isn't there a possibility of catastrophic oscillating events when one switches on and one switches off?
    Jan 2018
    1516
    Re: Connecting SMPS in parallel?
    Quote Originally Posted by pokmo View Post
    Hi
    Why risk it when you can get switching 24v/36v/48v power supply for <£30?
    May 2020
    Quote Originally Posted by dazp1976 View Post
    Yeah, I know I could get a Meanwell and save the hassle, but where I am only licensed electricians can legally work with mains.
    Nov 2012
    1267
    There are special power supplies designed for working in parallel and sharing the load. Regular switching power supplies should not be paralleled.
    If you have separate stepper drivers, you can use a separate power supply for each one of them. That would be OK.
    Jan 2018
    1516
    When you say mains it's not like you're moving sockets and channelling walls etc.
    Technically all you need to do is get a 3 core cable say 1.5mm2, stick a plug on it, and connect it to the psu terminals.
    Or if you find an old washing machine or similar with 3 core. Cut a length of cable off it with the plug still fitted and just connect the other end to the psu.
    There's more chance of you going bang and more dangerous if you start pratting around with trying to parallel ATX stuff.
  1. SMPS Power Supply
    By DenizYILDIZ in forum Stepper Motors / Drives
    Last Post: 03-21-2015, 08:20 PM
  2. 24V from SMPS power supply ...
    By CNCpatriot in forum Stepper Motors / Drives
    Last Post: 01-18-2011, 05:57 PM
  3. Connecting DRO to parallel port
    By zvika-g in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-21-2008, 10:55 PM
  4. Connecting Arc Welders in parallel?
    By Paragon36 in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2007, 02:08 AM
  5. Connecting 2 steppers in parallel
    By salvaCNC in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2007, 12:42 AM
