586,102 active members*
2,476 visitors online*
Results 1 to 6 of 6
    Jun 2015
    29
    Machine moved before received the arc OK signal
    Hi everyone, I have a issue with my plasma tube cutting cnc machine and I did'nt solve it yet. Could someone help me.
    I tried to cut the tube 27mm dia with the thru hole 10mm in the face and the first line cut is perfect, the remaining subsequent only partially cut. It seems with the pilot arc torch there is a delayed start each time it fires. The torch fires a second or two after the circle pattern has already started movement. The torch does not fire instantly. I have increased the pierce delay but that didn’t seem to help. Thanks a lot
    Nov 2007
    17
    Re: Machine moved before received the arc OK signal
    What brand machine and what software are you using? Some machines (Plasmacam for example) have a setting that will keep the machine from moving until the arc is detected. Perhaps check your software settings to see it that option is available for you.
    David
    Attachment 443706
    Jun 2015
    29
    Quote Originally Posted by adbuch View Post
    David
    Many thanks David, I'm using machine which I diy myself with cnckad V15 CAM software. It seems to be come from the controller, I guess. Because when I cut the same part in the cutting list. It worked fine for a period of time (the cutting part be always cut off) and then the problem occured with the subsequent part (as the pic below). I even gave up the THC and used the M3 / M5 command to start / stop directly the plasma source and the end result remained the same.
    Nov 2007
    17
    From what you are saying: " It seems with the pilot arc torch there is a delayed start each time it fires" perhaps this is caused by the plasma cutter (torch). If you can edit your G-code, perhaps you could insert a dwell G04 to introduce a delay long enough to wait until the plasma cutter is ready to cut again.
    David
    Jun 2015
    29
    David
    That's good idea. I will give it a try. Thank you so much David .
    Nov 2007
    17
    Let me know what happens and if you have any improvement.
    David
  1. Peru customer received our machine, very satisfied with our machine
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 04-25-2020, 04:23 AM
  2. Replies: 1
    Last Post: 11-04-2015, 06:01 PM
  3. Received Machine - Missing some parts?
    By Noyrt in forum Fadal
    Last Post: 07-31-2015, 02:56 PM
  4. SCAM COMPANY- Never Received CNC machine- National Automation
    By RRiveter in forum Complaints and Praise Discussions
    Last Post: 12-05-2013, 02:06 PM
