586,106 active members*
3,142 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > mach3 running xylotex 3axis weird problem
Results 1 to 7 of 7
    Feb 2007
    505
    Hello everyone , I have a problem with xylotex , I am pretty shure all my setting on mach3 are ok, when I turn power on I hear a weird sound on my Yaxis motor (almost sound like electrical arcing) now if I dont turn power off in a few second I know it will burn the board (happen before) . The current from the power supply is around 2amp when the motors lock-up . Is this about right?Now when this happen the current jump to about 7 amp on my clamp-on ampmeter before I turn it off. I have tried swapping motor location (did not help) the only thing that stop it beside playing around with the jog button is removing the parralel port cable (not much help there). So when the noise stop I can start like the roadrunner gcode program and it will run good until it end. After, if I dont turn it off, after a while the wierd sound will start again the current will jump up again.I am running windowxp with sony viao multimedia computer , my LPT1 driver file is c \windows\system32\drivers\parport.sys.Now when this is not happening the current on each motor is about 1.6amp (each step and direction)425OZ-IN motor measured with a clamp-on upon lock-up and only increase about .2amp when working.Could this be a computer problem I am getting a bit desperate here. Any ideas anyone?
    Possible a wiring problem, or a short in the stepper. Nothing to do with the PC I don't think.
    Feb 2007
    505
    weird problem
    Well could a wiring problem or a short stepper motor be intermittent?Cause when its ok I can run the roadrunner file twice without any problems all my motors run smooth ( over 30 minutes ) but when it end, if I leave it sitting there , the sound will start again the current will jump up and I will have to shut it down. The only way to stop that for awhile is by playing with the jog buttons back and forth or as I just find out to disconnect the parallel port cable.With the parralel port disconnected the problem will not start again.I had read somewhere that new computer had less powerfull parallels port output or something? Although it run fine when it does.My computer run pentiumDcpu 2.80ghz 512 Mb ram.
    Lpt1 driver C\windows\system32\drivers\parport.sys.Thanks for answering.
    Jun 2003
    3312
    How do you have your enables setup? If you have them jumpered as always enabled, change ti to make sure they are disabled until your ready to run.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Feb 2007
    505
    Thanks ger21
    You were right ger21 wiring was my problem leakage through shield I gess.I was using 4 wire connectors (trailer lights type) so when I soldered the wire I did not stripped the shielded wires long enough and the insulation melted under the jacket so it pass unnoticed. Thanks
    Jul 2007
    28
    Replace to motor
    If the X and Y motor the same can you replace Y by X and see what happen?
    If theproblem transfer to X axis the the problem in Y motor but if the problem still in Y axis then the problem on the stage befor motor maybe short ciruit on wiring
    good luck
    Feb 2007
    505
    weird problem solved
    The weird sound and lost of control of stepper motor were due to induced voltage on vref line , you need to insulate the db25 connector from the xylotex board so your computer ground does not touch your junction box ground.(Before I did this I could not ground my motors shield) Thanks everyone
  1. New FeatureCam Mill (3axis) and Turn Posts for Mach3
    By chris59 in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-05-2008, 08:43 AM
  2. Weird Problem Possibly Due To EMC2
    By juzwuz in forum LinuxCNC (formerly EMC2)
    Last Post: 12-20-2006, 08:53 AM
  3. Weird problem with HHain post...
    By TEX123 in forum Post Processors for MC
    Last Post: 11-25-2006, 11:29 PM
  4. xylotex and mach3?
    By tiktok in forum Xylotex
    Last Post: 10-18-2006, 04:26 PM
  5. Buy Xylotex 3axis, need breakout box?
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 05-26-2005, 03:47 AM
