586,080 active members*
3,625 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How CNC lasers manage such high feed speeds?
    Jan 2020
    39
    I can't find any info online as to what drive mechanism they use to achieve such high acceleration and speed (more than 100m/min) (could someone translate this to inches/minute)
    I've heard that some machines achive up to 6G of acceleration and 5m/second which is insane!!
    Of course, lasers don't have to deal with any cutting forces so they can make the gantry as light as possible, but still I think we could learn a lot by looking at the design and mechanism of such machines.
    Sent from my SM-G970F using Tapatalk
    Jul 2014
    63
    Re: How CNC lasers manage such high feed speeds?
    Not sure if this applies to the lasers you're talking about but many cnc gantry lasers only move a small mirror, the actual laser tube, etc, is fixed. And because of no cutting forces, everything is optimized for being light instead of being able to withstand force.
    Just a very different set of engineering and design requirements!
    Sent from my SM-G960U using Tapatalk
    Apr 2004
    733
    Most laser use the mm/sec designation for speed.
    100meters/min = 1666mm/sec
    Or 65inch/sec
    Or 3900in/min
    The highest end Epilog and Trotecs have no problem reaching these speeds. I think the Trotec Speedy goes even faster. These machines are belt driven with fast servo motors.
    My cheap 40watt laser is capable of 500mm/sec and is just using simple nema17 stepper motors.
  1. Fiber lasers. Good/Bad experiences, cutting speeds, problems, automation
    By BrunnerCO2 in forum Fiber Laser Cutting Topics
    Last Post: 02-06-2018, 06:07 AM
  2. Automatic feed / Speeds far too high??
    By ferrumdg in forum BobCad-Cam
    Last Post: 02-08-2014, 01:58 PM
  3. cutter leaving feed lines at high feed rates-walter prototyp end mill
    By shimmwagen in forum DNC Problems and Solutions
    Last Post: 02-07-2014, 11:44 PM
  4. Replies: 0
    Last Post: 01-23-2014, 08:54 PM
