586,061 active members*
4,456 visitors online*
Results 1 to 6 of 6
    May 2020
    19
    Setting soft limits automatically after Ref All axis
    Hi ppl.
    Today I just notice that on my plasma machine, when I refernce all axis to home, the softlimits do not toggled on automatically! However, on my cnc mill, this gets activated automatically after the first ref all is done!!
    Can someone tell me the correct script edit needed to include an automatic soft limit button activation after all axis are referenced, please?
    Should the Dobutton( 29 ) work??
    Note, I am no programmer, I just know from what I read.
    DIM
    May 2020
    19
    Re: Setting soft limits automatically after Ref All axis
    Hi again,
    I am still trying to figure out how to get Mach 3 to auto toggle the soft limits after the Ref all is completed!!! Like I said I am no programmer, however from what I read I would like to verify if the following script is correct for what I what (so I start eliminating the issues):
    DoButton( 24 )
    DoButton( 23 )
    DoButton( 22 )
    DoButton( 25 )
    While IsMoving()
    Wend
    DoButton( 29 )
    So, this should Home the X,Y and Z, set them to Zero and then the last thing activate the Soft Limit button.
    Is the correct?
    Thanks guys.
    Dim
    Nov 2012
    1267
    DoButton(29) toggles soft limits, so that's not what you want. I could not find any button that puts soft limits to a predefined state.
    Question is, how and why do soft limits get turned off on your machine? I turn them on when I install Mach3 and never touch them thereafter (except in some very rare circumstances).
    May 2020
    19
    Quote Originally Posted by CitizenOfDreams View Post
    Thank you very much for your reply.
    SO now I am more confused! This is the thing, I have two machines (both DIYs), one CNC mill other CNC plasma. On my mill, every time I turn it ON, I home all axis (with the RefAllHome buttom) and after all axis hit their limit switch, Mach3 automatically puts my Soft limits ON. Here I want to add that when I open Mach3 by default the Soft limits are OFF.
    So recently I ve been playing with the plasma CNC, and noticed that when I home all axis, the soft limits do not toggle ON automatically, I would need to go and click on the Soft Limit button from the Mach 3 screen.
    So why do I have two cnc machines which are nearly identical and Mach 3 works different? (I know Mach 3 is running different profiles, but I have set both machine nearly identical).
    All I wish is to have the soft limits turned ON automatically....
    Thank again
    Dim
    Nov 2012
    1267
    Quote Originally Posted by d3workz View Post
    Turn them on, save Mach3 settings and they should stay on forever until you turn them off deliberately. At least that's how it works for me.
    If GetOEMLED(23) = 0 Then 'If its off, turn it on
    DoOEMButton(119)
    End If
  1. MACH3 SOFT LIMITS – Main screen soft limit button will not illuminate
    By HANZC in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2019, 12:46 AM
  2. Mach 3 - "Software Limits" Can't turn off Soft Limits
    By MattWiese in forum Mach Software (ArtSoft software)
    Last Post: 10-23-2017, 05:10 PM
  3. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  4. Replies: 3
    Last Post: 03-08-2011, 07:14 AM
  5. Automatically setting Z height
    By matth in forum DIY CNC Router Table Machines
    Last Post: 09-05-2006, 09:03 PM
