586,108 active members*
3,073 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > is the Dynomotion controll as confusing as it seems?
Page 4 of 9 23456
Results 61 to 80 of 170
  1. #61
    May 2006
    4045
    Re: is the Dynomotion controll as confusing as it seems?
    Is the 4000 RPM the Spindle RPM or the axes motor's RPM?
    The supply voltage must be DC. Do you understand the difference between AC and DC? Regulated and unregulated?
    Is there an existing original power supply?
    Note there is also a "regenerative braking" issue to be aware of. When a mass/motor stops, mechanical energy is converted to electrical energy. The motor acts like a generator. Think of conservation of energy. The energy must go somewhere. The energy will normally be injected backwards into the power supply. Some power supplies don't like this. They like to give power but not receive it. The voltage can rise and damage the supply or the amplifier. Unregulated supplies with big capacitors are better at absorbing energy.
    TK
    http://dynomotion.com
  2. #62
    Quote Originally Posted by TomKerekes View Post
    Yes, I was referring to spindle speed I forgot were talking about servos..
    Somewhat, I know the definition of AC/DC as for what they do, not really. Regulated and unregulated, No, Ill look that up. The most training on electrical I had was when I was in the NAVY 20 years ago, but haven't worked with is sense.
    No. I do have 2 xtra power supplys but its 12v and 24v. The power supply I do have are AC to DC.
  3. #63
    May 2012
    537
    Quote Originally Posted by Gunmachinist View Post
    I'm not sure these are the same that came with the boss. I believe the machine I have was retrofitted around 1992 +/-. Here is a pic of the servos and machine so you get an idea of what im working with.
    Most of those Bridgeport Boss mills originally came with steppers. A friend of mine has a very similar machine that we retrofitted nearly 20 years ago with geckodrives and turbocnc, kept using the origional stepper motors. Still running today and he still uses it regularly.
    Those motors should work fine with the right encoder and drive. Sounds like you guys are on the right track.
    One more thing about that machine. My friends had variable speed pulleys for rpm adjustment and they were worn a little. He eliminated all those pulleys and used a single ratio with timing belts and then added a VFD to adjust speed. He seemed to think it was a much better setup. Just passing along the info in case your drive system causes the same trouble. Good luck with the project
  4. #64
    I was able to get my first axis wired up and the servo is spinning. I have the Z axis amp to servo, encoder, limitswitch all wired to 0. Now do I need to ballance the servo or establish the ability to communicate with the software?
  5. #65
    May 2006
    4045
    Not sure what you mean by "spinning" or all those things "wired to 0".
    Please put more effort into describing what you did.
    Once the hardware is interfaced you can use this method to begin testing.
    TK
  6. #66
    Spinning: the 5/8 shaft of the servo motor was spinning (moving in a circular motion) clockwise. Best I can do. may be called something different in California but down here in the south we call it spinning, It's what happens when you go in a circular motion.
    SRY, I was typing at work on my phone during break and didn't have time to explain in detail. Thanks again for your help...
    Here is a drawing of how I have the wires connected at this moment.
  7. #67
    May 2006
    4045
    I was looking for a description of how it was spinning. ie. was it spinning out of control? Was it creeping when it should be stopped? Was it servoing and moving in a controlled manner the number of revolutions commanded? What were you commanding it to do? What was it doing?
    The wiring diagram doesn't have any of the connections labeled. We can see you have 11 wires going to the amplifier but not what they are connected to.
    The Encoder should be a +5VDC device and should be supplied +5VDC. Normally it would receive +5VDC from Kanalog. But you show it connected to the Amplifier. This seems wrong. Please don't power up the system until you understand this.
    A limit switch connected to an opto input will not work. Just like a light switch connected to a light bulb will not cause the light to come on. A power supply is required. You might use your 24VDC power supply, run it through the switch and the opto to form a circuit.
    HTH
    TK
  8. #68
    Made some corrections, Is this better?
  9. #69
    May 2006
    4045
    Hi Gunmachinist,
    Better but:
    #1 - it seems you are wiring the 24V motor power through a KFLOP Opto output. Opto Outputs can only switch small currents 0.025Amps not 11Amps. There should be a direct GND connection between the Motor Power Supply and the Amplifier.
    #2 - The encoder is still getting its +5V power from the Amplifier instead of Kanalog. +5V and -5V would apply 10V to the encoder not +5V and also the +/-5V from the amplifier is only good for 3ma. Probably not sufficient to power an encoder.
    #3 - Limit switch seems unclear and all wrong. Consider how you would connect a battery, a switch, and a light bulb in a circuit (complete loop). The Opto is similar to a light bulb.
    Attachment 445920
    #4 - the green wire from the motor (probably a shield) should probably be connected to Earth GND not Motor Power GND.
    TK
  10. #70
    Hi Gunmachinist,
    Better but:
    Im going somewhat off one of the drawings(2nd one down) on your wiki site, which shows 24v power routed through JP15.
    Where should I connect it, I'm lost as you can see.
    So how would I connect it? I'm lost but if I could get one connected and operating I think I could get the rest connected correctly.
    Corrected.
  11. #71
    May 2006
    4045
    Hi Gunmachinist,
    Better but:
    Correct but the +24V is routed to the enable input signal of the Amplifier not the main power input.
    Connect to any +5V terminal on Kanalog and any GND terminal on Kanalog.
    The circuit current should flow in a loop from the power supply, through the Opto, through the switch, then back to the supply. Just like the light switch circuit posted.
    Add a wire from +24V to Opto In 0 +
    Add a wire from Opto In 0 - to the switch
    Add a wire from the other switch pin to 24V-
    Corrected.
    No Earth GND and Power GND should not be connected
    The 24V Power supply probably shouldn't have an Earth GND. (remove the Green GND from it)
    Add a wire between power supply 24V- and Servo Amp Power GND
    I'm tempted to just make the corrections for you, but then I worry you will not understand them, not be able to do the next steps, possibly wire things incorrectly. So please have patience.
    On an additional it isn't clear what the unmarked 5 wires from the motor actually are. So we are guessing they are the motor leads, tachometer leads, and shield. Having these wrong may cause damage. How did you determine what they are?
    TK
  12. #72
    Absolutely. Is there anywhere I need an earth ground?
    Thats the best I can figure, I can't find any wiring information for these servos.
  13. #73
    May 2006
    4045
    Progress
    Grounding is very complex. I think your Earth grounding (green wiring) is basically all wrong. Assuming the G terminal on the motor is the shield/case of the motor (you could verify this with an ohm meter testing for continuity). that is the only thing that should be connected to Earth GND. Remove all the other green wiring,
    The Green wire to the 24V Power Supply, I'm not sure what that is (again no label on the connection) should probably be removed.
    The black wire (I'm assuming that is the Encoder GND for the 5V) should be connected to a Kanalog GND - Not Earth GND.
    The limit switch wiring looks correct
    You could probably verify with an ohm meter. The Tach resistance is usually much higher than the motor resistance. Also there shouldn't be any continuity (very high resistance) between the tach and motor wires.
    TK
  14. #74
    The grrn wires are just routed through that terminal strip not to earth. Coloring them green just helps me see what im doing.
    The tach wires from the servi motor are white(+) and white/black(-) possibly pos(+) and neu/neg(-).
  15. #75
    Here's an updated drawing, I added a terminal strip for the 24v power so I could better route power.
  16. #76
    May 2006
    4045
    I don't understand what you mean or how you know this or if you measured the resistance as I requested.
    It seems all wrong. I think all the green wiring should be removed, with the exception of the one earth ground connection to the servo motor case. Otherwise you have the encoder GND, the power supply Ground (not even sure what this is), the encoder GND, and the Amplifier Power GND all shorted together which would be bad.
    So:
    #1 remove all the green wires
    #2 connect the encoder GND to any Kanalog GND
    Note Power Supplies can be confusing. It isn't clear what kind of 24V and 5V supplies you have. Firstly they should be separate and isolated. You show one box with both. Maybe you have a PC ATX Power supply? Those have a common GND which is not ideal.
    Secondly there are 24V supplies and dual supplies that output both +24V and -24V. It isn't clear what type you have. With a simple single ended +24V supply the "return" pin is sometimes called GND, sometimes called 0V, and sometimes called 24V return, and sometimes called 24V-. So hopefully your Power Supply Pin marked 24V- is really a GND not actually -24V. If you measure the voltage from 24V+ to 24V- do you measure 24V or 48V? (do not connect anything to the power supply before understanding this).
    HTH
    TK
  17. #77
    I don"t have an ohm meter so I have no way of doing this.
    HTH
    See pic it's actually Comm I was mislabeling it.The power supply I have installed will supply 25V and 5v from different connections.
    Would I still connect the black power wire from servo encoder to a Kanalog ground if it were a 5V comm connection?
    Attached Thumbnails Attached Thumbnails Mill servo wiring.jpg   20200720_042952.jpg   Mill servo wiring.jpg
  18. #78
    May 2012
    537
    Doing a CNC retrofit without a multi meter is like trying to build a house without a measuring tape!
    Well worth the money to buy a decent meter. At the very least get a cheap one, they can be had for next to nothing these days. Watch some youtube videos about proper use and all the features. Every extra thing you learn like that will help you out in the end with your project.
  19. #79
    May 2006
    4045
    You should obtain one. They are very important to have. Here is one for $10 on Amazon.
    Yes from a noise perspective I think that is best.
    The diagram now looks correct to me!
    I'm not sure what the Relay Connections are.
    It would be good to give KFLOP the ability to Enable/Disable the Motor Drive. I believe switching the Amplifier's Inhibit pin to Signal Ground will disable the drive. A KFLOP Opto Out should work for this. You might also read this and this.
    TK
  20. #80
    Ok, guys. I think I may be loosing my mind, I do have a fluke and another cheap multimeter, I apologize. I was thinking of an O scope for some reason.
Page 4 of 9 23456
  1. Use co2 laser machine controll card to controll 30W fiber source
    By oneeye in forum Laser Control Software
    Last Post: 06-12-2020, 05:23 PM
  2. Confusing breakage
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 09-07-2013, 04:01 AM
  3. Confusing diagram
    By sirevert in forum Stepper Motors / Drives
    Last Post: 09-25-2009, 08:57 AM
  4. DATA BIT 8 AND 7 CONFUSING
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-24-2009, 11:08 AM
  5. BobCad-Cam V21.5 is confusing
    By jessey in forum BobCad-Cam
    Last Post: 05-24-2009, 10:43 AM
